(Topic ID: 213181)
hello from france...problems with my rollergames
By maltoch
6 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by maltoch
    #1 6 years ago
    hi
    i hope i m on the good sub forum...
    move it ...if its not on the correct sub forum.
    my rollergames suddently have problems since 2 months of no games.
    first i had no diplay..nothing
    second...the start button doesn't work
    flips and bumpers work without starting a game.
    left and right 5v leds are ok .always on
    center led bkinks all the time.
    hope some of us could help me.
    thanks
    #2 6 years ago
    Reseat all cables on display , pull off and back on . At actual display and board.
    Test start button in test mode , make sure it works .
    Not sure why flippers are energized in attract mode .
    Game won't start ? Sure the batteries aren't dead and it's no longer in free play mode?
    That's all I can suggest , but I bumped you back to top
    #3 6 years ago
    thanks to your reply...
    i reseated all the cables on the display and on all the boards...nothing better...display still doesn't work.
    i replaced the batteries...and maybe it's one of my 2 problems....batteries were surely died...
    i put the roller no games on....opened the door....disconnected the coins cable fewer times and it gives me at least 4 credits....so i suppose the free play mode was deleted...but because my display doesn't work, i can't enter in the system to reset it to free play mode....
    i could reset it when my display will work.
    well the pinball reworks ....all work....sound too....
    i still have a display problem.....wait for suggestions....
    #4 6 years ago
    Quoted from maltoch:
    Did you check the 3 fuses for the high voltage on the power supply?
    #5 6 years ago
    thank you for your help too.
    i checked and rechecked all the fuses everywhere...nothing wrong.
    on power supply board ...all the fuses F1 TO F5 are ok.
    #6 6 years ago
    i checked voltages at j2connector....4 wires on it....connector in place on board....i found the +5V, the ground, and no 100 volts....i think my supply board has died ...
    Zr2 and zr4 seem to have been hot and there is a strong smell near these parts...
    i don't know if i do the things correctly ...is it a good method ? i'm not a pinball expert and have only this pinball.
    #7 6 years ago
    sounds like a bad power supply board. Try a new Rottendog board.
    #8 6 years ago
    i ve just take a look at this power supply board.
    i suppose for the purist ...it should be a demoniac board and they prefer to repair the stock one but this board isn't expensive and is a direct replacement....
    This page was printed from https://pinside.com/pinball/forum/topic/hello-from-franceproblems-with-my-rollergames and we tried optimising it for printing. Some page elements may have been deliberately hidden.
