Hi all,
Just thought I'd take a shot in the dark with this...
Has anyone experimented with finding the best temperature to have a heat gun set at to loosen up the adhesive for WPC side rail removal? I have a digital heat gun that can bet set between 250-1350 degrees Fahrenheit , and I was just wondering if anyone knows what the "safest" setting would be that also delivers the best results.
Just to be clear, I'm referring to heating up the double sided tape between the side rails and the cabinet in order to (hopefully) remove them with our damaging the rails, or the cabinet. I'll be using the painters tape/scoring method using two 1 1/4" flexible putty knives to piggyback along the rails while removing.
Any advice would be greatly appreciated as always!
Cheers,
Greg
