(Topic ID: 232190)
Have I bricked RZ?
By allicks
1 year ago
  • 18 posts
  • 10 Pinsiders participating
  • Latest reply 1 year ago by benheck
#1 1 year ago
Purchased an RZ today in not working condition. Game would state missing balls and not start. I went to reload the software and followed the process outlined on Spooky's website but once I went to restart the machine as instructed on the DMD, I've received the error Connect PIC32 : FAIL when powered back up and the screen instructs me to restart. I've wiped and reloaded the card to no avail. The game seems bricked now. Anyone come across this before?
#3 1 year ago
Quoted from allicks:
Try this procedure from Fawzma. If this doesn't work you'll have to send the board in to Spooky.
#4 1 year ago
seems like good advice.
#5 1 year ago
Missing balls and not starting is not Software. You more than likely had a bad switch shorted I have the same problem, the common switch that get shorted that affects that switch line for the trough is the switch on the bottom side of the upper playfield “gas” target. The Ball actually bends the diode and will short the switch.
#6 1 year ago
mine was the same problem of the ball hitting the upf switch I think if you run a test it says switch 23 fail
#7 1 year ago
Quoted from pballinhd:
Try this procedure from Fawzma. If this doesn't work you'll have to send the board in to Spooky.[quoted image]
Awesome that worked! Very glad you had that. So software is reloaded but still missing balls. Will look under the secondary playfield and check anything associated with the trough in the switch matrix.
#8 1 year ago
Quoted from pumba:
I am showing one closed switch I wonder if it shouldn't be? Trying to get used to this menu lol. Will get under the 2nd pf and report back.
#9 1 year ago
Quoted from mnpinball:
Will check this out and report back.
#10 1 year ago
Ok so the switch did appear to be compromised. I bent the contact back and the switch registers proper but still missing balls.
#11 1 year ago
You can download the switch matrix sheet from spooky’s website under game support.
Check the easy things first. Loose/broken wires to the trough switches, diodes on the trough switches.
#12 1 year ago
Balltrough has a number of switches and instead of one on ball one, it is relocated at the end of the trough. Because it has constant pressure against switch whenever a ball is in trough. It is not engineered enough. Try looking at that one also, it might be flaky.
#13 1 year ago
Is it still giving you this message when you try to update?
#14 1 year ago
Don't screw up my old game Alex, lol
I'm sure you will figure it out.
#15 1 year ago
Try this procedure from Fawzma. If this doesn't work you'll have to send the board in to Spooky.[quoted image]</blockquote
Quoted from pingod:
All fixed Dan!! Game is now playing perfectly. The one cherry switch at the vuk in the trough was the suspect for the missing balls. With playfield up on the arm, the cherry switch would register, but noticed it wasn't registered with the playfield in place. Adjusted switch and off to the races!
#16 1 year ago
Quoted from benheck:
Hey Ben, holding the button worked and took the fresh load. On a sidenote, never seen one of your boards til last night. Really love how you laid it out!
#17 1 year ago
Quoted from jeffspinballpalace:
This was the issue exactly. Agreed this switch is poorly engineered.
#18 1 year ago
I only designed the circuit, layout was by Parker Dillmann! But thanks!
$ 79.95
4,300 (OBO)
Chattanooga, TN
Pin Mods
$ 107.95
Hookedonpinball.com
