(Topic ID: 301425)
Haunted House - what is this relay?
By nikkifury
2 years ago
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 11 months ago by 2manypins
#1 2 years ago
Good evening,
I am chasing some errors around my Haunted House. Currently the bottom up kicker and after my testing that the out hole has stopped working now.
I have looked around can i ask what is this?
the only way i can see this working as a relay is magnetism.
i had a short and it blew that fuse, but the game was playable if you didn't go downstairs and sit on the upkicer.
but replacing the fuse didn't fix it and after testing the upkicker coil and diode (which seem ok if a little low 3 ohms on the coil) i reseated the metal plate on the K-relay
now get a out hole coil error on game start! that K-Relay and the out hole seem to share Fuse 15 which is fine.
so once again i come to the font of knowledge for advice!
cheers guys!
#2 2 years ago
the K relay works the up-kicker
#3 2 years ago
i think it's Q13 on the driver board that if you ground the tab it should fire?
#5 2 years ago
thanks @rikoshay.
I figured it had something to do with the delay on the upkicker. but should it be open/closed and mechanically how does move that plate to close the switch?
something else... the brown/black/black wire goes back to the connector. but it connects to nothing on the other side... i cant see any dangling wires the other side.
#6 2 years ago
One connection to that fuse clip that goes to the solenoid looks like it only has a few strands of wire making the connection.
Check that to make sure there is a good connection there.
#7 2 years ago
Dent00 i did look at that, even the wife said that looks bad. as i was looking at other faults i just put a MM on it and it said 0 OHMS so i thought i'll come back to that!
#8 2 years ago
The switch is open until engage and it works with magnetism. The plate is pulled towards the relay.
#9 2 years ago
Quoted from nikkifury:
I'm not saying that this is your problem, but with just a few strands making contact, the resistance of the connection could be high enough to restrict the current to the coil when it tries to operate.
#10 2 years ago
thanks Mach1 I was 90% sure that's how it worked but you have to be 100%. im going to set some time aside today to work on it.
1 year later
#11 11 months ago
Mine is different than yours
$ 83.00
PinballReplacementParts
$ 1.29
Daddio's 3D Printed Mods
Toast-Mach1 Mods Shop
$ 1,159.00
2,950 (OBO)
Shakopee, MN
3,950 (OBO)
Centerport, NY
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/haunted-house-what-is-this-relay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
