(Topic ID: 190980)
Haunted House upkick help
By mtbpinball
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by Grizlyrig
#1 4 years ago
My up kicker from cellar to main playfield works fine but barely kicks hard enough. Once in awhile it works fine but most of the time kicks hard enough the first and maybe second time but falls back down. After the first two attempts it won't kick hard enough to get it out of the hole. I have tried repositioning everything with limited success any alterations that work good I have a new coil in it that's not the problem. Anybody do anything to get rid of this problem I appreciate the help
#2 4 years ago
If you've double checked all the hardware, then maybe I'd check the transistor that drives that particular coil...maybe it's not doing it's job 100%?
#4 4 years ago
Thanks I will check all that out to see what size coil is in there I also read where some people put a pop bumper board in there and that helped solve the problem. I will also check the transistor to see if the output is correct thank you for the help
#5 4 years ago
In the TNT video Todd says coil change to A-4893. I had did this to mine and added a new switch. Made a great difference.
-Mike
