Hi All,
I read in Clay's guides and Pinwiki that you should add pull-up resistors to the under-playfield transistors on Haunted House, see here:
https://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80#Remote_Mounted_Transistor_Update
Has anyone done this? I'm wondering if I need to add a resistor to the transistor under the lower playfield? If so, where can I find the 24V to connect the resistor to?
Right now it is a 2N5875, so I'm planning on replacing it with a MJ2955 as recommended. I have attached a pic of the transistor in question:
