I posted a while back about a Gottlieb Haunted House that I was fixing for a friend. When I first started the machine was mostly functioning. Everything worked but a few pop bumpers - It desperately needed some rubbers and a bath. After cleaning it up it seemed that everytime I turned it on something else decided it may or may not work. Fast forward to the present and here is what I've got:
I installed a new Rottendog MPU, Driver Board, and Power Supply - I also installed a new connector harness from the Driver board to the MPU. Sadly when I turned it on almost everything was the same, if not worse. I'm now getting intermittent audio, missing credit display, and game resets. The upper and lower playfield are both inop with the exception of the drop target resets. This is the first System 80 I've worked on and I think I need a Dummies Guide to Gottlieb. I know I've got a wiring or grounding problem somewhere. Any suggestions?
Thanks!!
Mike V.
Anybody in the Delaware area that wants to swing by and take a look?
