(Topic ID: 229439)
Haunted House playfield swap
By Bryan_Kelly
1 year ago
  • 234 posts
  • 46 Pinsiders participating
  • Latest reply 1 year ago by TomGWI
  • Topic is favorited by 45 Pinsiders
    There have been 167 images uploaded to this topic. (View topic image gallery).
    There are 234 posts in this topic. You are on page 3 of 5.
    #101 1 year ago
    Quoted from Bryan_Kelly:
    and no V cut behind the drop targets.
    I'm curious what are you gong to do in this case, or is the cutout not required?
    #102 1 year ago
    Quoted from kickthefog:
    I haven't gotten to the point where I know just yet. Just glancing at things, it doesn't appear that the cutout is needed.
    #103 1 year ago
    More parts out of the tumbler.
    #104 1 year ago
    That's a relief! I was a bit worried. I know if I had to somehow cut that out, I'd screw it up for sure.
    May the wind continue to be at your back!
    #105 1 year ago
    Lots of wire guides. I’ll drill a 3/32” hole for these. My spacer guide is 3 paint stir sticks and a plastic ruler.
    kicking it old school. I like that, bryan!
    I'm assuming that puts the center of the ball guide at the center of the ball in terms of relative height
    #106 1 year ago
    Quoted from j_m_:
    Yes, sir, it does. This isn't rocket science. Stir sticks and plastic ruler work just fine.
    #107 1 year ago
    The new playfield has recessed holes for the 4 T-nuts and no V cut behind the drop targets. I wonder how many versions of these were made?
    [quoted image][quoted image]
    Looking at pics on ipdb and here
    http://www.hsapinball.com/HSA_PINBALL/hsa082114hh.html#73
    it would appear that the V notch behind the upper do targets was not required.
    #108 1 year ago
    I LOVE the dimples. No predrilling needed.
    #109 1 year ago
    Quoted from j_m_:
    He can't help but kick it old school,
    Following by the way. Wish my F-14 had those dimples!!!!!
    #110 1 year ago
    Time to deal with this mess.
    #111 1 year ago
    Looks like you are moving right along> wanna do mine next?
    #112 1 year ago
    Quoted from woz:
    What ultrasonic cleaner are you using bryan_kelly ?
    I'm going to be doing a Black Hole playfield swap soon so will be watching this thread closely. Thanks for sharing your experience!
    Interested in this, I am trying to figure out if I can swing the funds to buy the BH playfields myself.
    #113 1 year ago
    Quoted from woz:
    Turns out the lower playfield has a 5 target bank that has a switch mounted in the back, which requires the notch. The upper playfield has a 4 target bank with no switch.
    #114 1 year ago
    Quoted from heni1977:
    yeah, with bryan I think they just called it "school" and all of the kids were in a single room with one teacher for grades 1-12
    #115 1 year ago
    Bare wire stapled back in. I set the regulator at 75 psi. With higher settings, you stand the risk of cutting the wire. Don’t ask me how I know this. I said DON’T ASK!
    #116 1 year ago
    Needles to say, not all the dimples are perfect. Even though they’re close, you’re going to want to fine tune some to get perfect alignment of some of the parts.
    #117 1 year ago
    That’s it for the backside, minus the drop target bank. I won’t have the new targets until tomorrow.
    There were a few dimples that didn't quite line up. They were close, but not quite. As always, make sure things line up before you use them.
    #118 1 year ago
    Last of the parts out of the tumblers.
    #119 1 year ago
    Looks like it can mess up the clear on the other side too - https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration/page/124#post-4693717
    #120 1 year ago
    The apron is really nice. I used nothing but water to clean it. I think most anything else will effect the ink.
    #121 1 year ago
    I saw that. I've done a lot of stapling on the underside of playfields and have never had this happen. Lesson learned from someone else....only use enough pressure to set the staples. 75 psi works for me.
    #122 1 year ago
    Just curious, are you doing this for a guy named Craig?
    #123 1 year ago
    After the rubber is installed, I’ll adjust all the switches.
    #124 1 year ago
    Quoted from Mombo-number-5:
    Nope.
    #125 1 year ago
    Does look great. I would add that 70s Gottlieb aprons can sometimes be prone to ink/graphics damage even with water. I always test a small area with just a q-tip before proceeding further. System 80 games may be more durable. Following your thread as these games use lots of Gottlieb parts common in the 70s. Great work. Thanks for documenting this for us.
    #126 1 year ago
    Main playfield is back in the rotisserie. All the wire guides were installed with the playfield on top of a solid workbench, not in the rotisserie.
    #127 1 year ago
    Small nail holes have been filled. Here’s how I then install the nails.
    #128 1 year ago
    Looking great!
    I always give all those slotted screws back to the owner, and change everything over to slip-free Phillips head screws.
    Makes the re-pop go 3x faster, and eliminates the chance of sliding out of the slot and damaging something valuable.
    #129 1 year ago
    Having never done a HH, I'll be taking a ton of pics.
    Your pics are nicely lit (and focused), you should consider putting the 100 best tear down pics on the HH Pinside Shopout Galery:
    https://pinside.com/pinball/machine/haunted-house/gallery/shopout
    #130 1 year ago
    Something I wasn't clear on, are the guide posts holes already there or did you have to find the place and drill them yourself?
    #131 1 year ago
    Quoted from vid1900:
    Looking great!
    It would be a lot easier to use different hardware, but I don't work that way. I prefer to use the hardware that came with the game....cause that's what came with the game. I want the owner to open the game up and have it look just like it did from the factory.
    I'll look into that when I'm all done.
    Quoted from Zablon:
    The holes are there. You'll want to drill them out just a tad, depending on the diameter of the guide.
    #132 1 year ago
    I hear ya.
    I always figure that no one is going to think that my restored **sheet of glass** playfield is anything near original, so using better fasteners is just one more improvement.
    (and unlike the playfield, screws are 100% reversible)
    Carry on with the good work!
    #133 1 year ago
    Underside of the lower playfield complete.
    #134 1 year ago
    Topside complete.
    #135 1 year ago
    Well. That didn’t go well.
    #136 1 year ago
    whose product was that ?
    #137 1 year ago
    That’s it for the top for now.
    #138 1 year ago
    Quoted from fast_in_muskoka:
    No idea who made it but it came from BAA. I'll contact Rick and have him send me another. I rarely ever have issues with his stuff, but when I have in the past, he always takes care of things.
    #139 1 year ago
    Topside complete.
    Looks awesome! Is the large light shield at the left end of drops cracked? Bummer if so...
    #140 1 year ago
    Quoted from stashyboy:
    It is. It's the only one cracked. At least it's on the lower playfield.
    #141 1 year ago
    looking through e-mails to see where this one came from ( I think it came from CPR ) :
    #142 1 year ago
    I recall reading a few posts months ago where others had the same problem with the spiderweb print lifting off when they removed the protective coating. It's possible that the whole run may be like that.
    #143 1 year ago
    I’ll be adding Mylar on the lower. Not sure how to configure it yet.
    #144 1 year ago
    On to the upper playfield.
    #145 1 year ago
    I can not lie. All the star posts are on and I have 2 longer ones I have no idea where they go. Of course I didn’t notice them when they were take off. I’ll find out where they go at some point. If anyone happens to know where these go, please let me know.
    #146 1 year ago
    Quoted from jibmums:
    Let's hope not. I've requested a new one and have asked them to remove the coating before sending. I'll see what happens.
    #147 1 year ago
    Targets are adjusted.
    #148 1 year ago
    Don’t forget the protective tubing on the pop bumper lamp leads.
    #149 1 year ago
    Target bank is rebuilt.
    #150 1 year ago
    Happens to me all the time.
    $ 7,399.00
    Pinball Pro
    $ 24.25
    The MOD Couple
    € 40.00
    YOYOKOPTER MODS
    $ 160.00
    Cabinet - (Alt) Translites
    Lit Frames
    € 4.20
    Buthamburg
    $ 32.00
    $ 84.95
    $ 16.95
    $ 68.00
    $ 1,199.00
    $ 10,900.00
    RMV Sales
    $ 79.95
    $ 125.00
    Sparky Pinball
    $ 35.95
    MicksPinball
    $ 179.99
    $ 48.00
    $ 48.00
    $ 4.49
    Yorktown Parts and Equip
    $ 90.00
    Lighting - Under Cabinet
    $ 85.00
    $ 224.99
    $ 48.00
