Hi everyone.
Looks like we have a problem with the general illumination playfield lamps on my Haunted House table. None of them are lighting up.
I've isolated and tested the power supply and it's running smoothly. The bridge rectifier responsible for powering on the lamps show all four lugs with the proper value of .4 to .6 (.49 to be exact in my case). I also ran my DMM through the rectifier with the game on and it's showing the proper value, cycling from 0V to 6.3V.
But as soon as I pop in an 8A fuse... FOOM... it burns out.
I'm curious to everyone's thoughts about what's happening. Could it be a short in the wiring for the lamps?
Also, I removed the power connectors from the lower and upper playfields so it appears that if it's a short then it's on the main playfield.
Am I heading in the right direction?
Now I know why this table is called "Haunted House". You fix one thing and something else goes wrong.
-Bob
