Hi I lifted the main playfield to work on the lower playfield and started a game (without ball). Without realising it, a switch was made and a minute later I noticed smoke from a coil on the main playfield. Switched it off and let it cool down but now when I try to play a game the Pascal board says 'Err 2' which apparently means 'no current is flooding through coil, although it is energised'. It says this for coil 9 which it the outhole (where the ball starts). When I go to test mode none of the coils fire and all say 'Err 2'. I've unsoldered coil 9 but the diode is good and the coil is good. I haven't tested the overheated coil or attached capacitor etc. I'm a total at this but it looks as though there is no current to the coil circuit?
When I checked further I discovered that one on the capacitors on the bottom of the cabinet had a loose wire which I reconnected but still no joy.
Any ideas? Could it have been the overheating coil? I attach photos of the overheated coil and the now reattached blue capacitor (think I wired it back correctly).
Matt
