Haunted House is great. The entire pin is a real work of art and also a fun pinball machine.
The music and art are great.
Here's a few tweaks i did:
a) raised back 2 legs up a little higher than normal to speed up game play on main & upper playfield.
b) had to fiddle a bit with the lower playfield -to- main playfield VUK so increase percentage of times ball would make it all the way up and onto main playfield.
c) used a large paperclip (unfolded at first) to put behind secret trap door so ball wouldn't go past hole and get stuck behind wire borders. just wrapped paperclip between them so ball hit it and would then drop into hole. couldn't ever see it as it was under the upper playfield and really too dark back there. plus, it was same silver color as wire borders.
d) mine had a real issue with wires coming loose from their solder points. don't know if it was just because of the life mine went through, or is a common aging problem. after lots of game-plays and that happening at several different spots, got them all back in place and all was good. super simple issue to resolve. just had to hunt them down.
also, MODS:
a) there's some cool little flipper topper mods that stick on top of the flippers that look really cool, if you're into that.
b) there's a multiball mod out there that wires into the PCB's in the backbox. haven't tried it.
c) think there's a mod that adds some speech. didn't look into it much, so don't know if it adds anything.
i didn't play it as much as tron, but i don't play any pin as much as tron
it's just an amazing work of art to have in the home as well.
Theme goes well next to Addam's family, Scared stiff, etc...
Hope it comes together well and you like it.
cheers,
bb
