(Topic ID: 39477)
Haunted House Help Please
By mkemp
8 years ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 8 years ago by Jesterfunhouse
#1 8 years ago
Various inserts lamp are flickering and a relay under main playfield is continuously opening and closing. Everything else works fine. Thanks in advance
#2 8 years ago
Mostly lightly its a bit of corrosion on one of your connectors in the backboard.
Common issue with Gottlieb System 80's. I'd open the head, re-seat all cable connectors first. Once you get that done, make a big cup of coffee and read;
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80
#3 8 years ago
And before you go too crazy,,, when you say relay opening and closing, is it random or about every 3-4 seconds? If its cyclic, that is normal for that game. What it does when idle is turn the general illumination off and on cycling between lower and main playfield.
The flickering on the lamps is not normal. If its all GI doing it, reset the connectors, if its one or two, wiggle the bulbs.
#4 8 years ago
I agree with PATOFNAUD. I just had a similar issue with my Haunted House where it would cut power to the displays in the middle of the game and the Relays would turn on and off every couple of minutes resetting the game. I took off all the connectors to the driver board. Cleaned the contacts and reattached the connectors and did not have any problems after that with this issue.
