I am having an issue with the displays on my HH. All of the displays pulse brighter and dimmer, some more than others, especially players 2 and 4. Players 2 and 4 displays will also slightly flicker every 5 seconds or so. This happens in attract mode and during a game. I can't tell for sure if it occurs in display test because the digits change too rapidly to see the pulsing. I think I did see some flickering.
I have done the ground modifications
I have cleaned and "tightened" the edge connections at the cpu. The connectors have already been replaced.
New power supply board and cable.
Reseated the block connectors going to the displays
Tried just having various single displays plugged and all the others disconnected with no change.
The game plays fine and the displays are otherwise correct.
Is this "normal" behavior for System 80 games or is there something else I should be looking at? I tried taking a video to post but could not capture the problem because of the type of artefact you get when you try to video a tv screen.
Thanks for any help.
Bruce
