(Topic ID: 318918)
Haunted House battery replacement
By stvns78
8 months ago
  • 15 posts
  • 5 Pinsiders participating
  • Latest reply 8 months ago by Knxwledge
#1 8 months ago
Hello, first post! I recently picked up Haunted House, my first machine. It was my favorite pinball machine at the skating rink growing up. We had Roller Disco at home which is the next one I want to get.
Luckily the machine came without the battery pack. It looks like it had leaked in the past but the damage seems to be minimal and does not affect the game in anyway I can tell. I am leaning towards a CR2032 battery holder and the blocking diode approach but was wanting to solicit options and recommendations for battery replacements.
I have referenced the pinwiki page for System 80: https://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80#Relocating_the_battery_from_the_MPU_board
Is there anyway to connect a rechargeable battery pack to the MPU or is the only rechargeable option the super-cap? If i use the coin cell holder to I need to drill any holes in the board or will it fit with the holes currently in the board?
#2 8 months ago
Quoted from stvns78:
Was it cleaned up properly? If not, it will need to be, otherwise the corrosion will continue to spread over time.
Not that I'm aware of.
It should use existing through holes.
You also have the option for NVRAM.
https://www.pinitech.com/products/5101_nvram.php
Scroll down on that page for instructions.
#3 8 months ago
For System 80 pins I always use memory capacitors instead of new batteries or NVRAM. A $5 fix that is good forever.
#4 8 months ago
Quoted from ForceFlow:
I had planned on using the vinegar, baking soda approach to cleaning it unless there is a better way. Rinse with water then rinse with Iso Alcohol?
#5 8 months ago
Quoted from Mad_Dog_Coin_Op:
Will any 5.5v 1F super cap work or is there one you recommend for the System 80 boards?
#6 8 months ago
Zep toilet bowl cleaner is more acidic and does a better job neutralizing the alkaline. There are a few threads on the subject. Caution: Use gloves, and don't use it in a metal sink unless it's heavily diluted, or it may permanently stain it.
#7 8 months ago
Searched up and read some of the threads on the subject. Sounds like you just apply that stuff directly, wait 5 minutes, then scrub with a brass bristle brush, rinse and let dry? Repeat if necessary? Does not remove trace overcoats and or harm anything else? The gel kind works the same?
#8 8 months ago
First, cut off any affected parts, expose any affected masked traces, then apply.
I haven't needed to use it in a while, but it may affect the silkscreened labels.
brass bristle brush
I just use a toothbrush.
Once the alkaline is cleaned up, sand down the copper a bit for a clean surface. Once you're done replacing the parts, seal exposed traces with clear nail polish.
#9 8 months ago
Any will work. I've tried many different types / brands and they have all worked for me. The trick is to find them cheap and in stock. My HH can sit for 6 months (or more) without losing settings (the game is at my vacation house). After 10 mins of play the cap is charged up and ready for another 6-month run.
amazon.com link »
#10 8 months ago
Went out and bought Zep and did two cleanings on the MPU. First pass just a tad bit of bubbles, second pass none. Scrubbed, rinsed with water, then rinsed with isopropyl, dried with the air compressor. Best part of all it still works
Ordered a 1F 5.5v super cap on Amazon.
Thanks for the help!
#11 8 months ago
[quoted image][quoted image]
Might wanna lay a new edge finger using copper tape on that one second to the right. Looks like its half torn in the photo
#12 8 months ago
After it is all done you should conformal coat the traces that were exposed copper from sanding.
#13 8 months ago
Quoted from slghokie:
I have purchased a green overcoat pen I plan on going over the traces before soldering on the super cap. Thanks!
#14 8 months ago
Quoted from Knxwledge:
If you are referring to the 2nd to the right on the backside, that pin has been reflowed in the past by parties unknown. Has good continuity. Thanks!
#15 8 months ago
It looks like the finger doesnt reach the edge of the board, and if thats the case it wont make as good continuity with the pin in the housing
$ 5.95
The Pinball Scientist
Protection
4,500 (OBO)
Ashton-sandy Spring, MD
Men
$ 83.00
PinballReplacementParts
2,800 (OBO)
North Mankato, MN
5,000
Westtown, NY
$ 1.29
Daddio's 3D Printed Mods
Toys/Add-ons
Toys/Add-ons
$ 1,159.00
Flipper parts
Toast-Mach1 Mods Shop
Toys/Add-ons
Other
3,500 (OBO)
Franklin, VA
This page was printed from https://pinside.com/pinball/forum/topic/haunted-house-battery-replacement and we tried optimising it for printing. Some page elements may have been deliberately hidden.
