(Topic ID: 263616)
Has anyone tried to bend a wireform to re-direct the ball?
By Beechwood
83 days ago
  • 8 posts
  • 7 Pinsiders participating
  • Latest reply 82 days ago by Beechwood
    #1 83 days ago
    I want to customize an existing wireform to direct the ball to the inlane instead of having it shoot right at the flipper. It is the right length and only needs to be bent over about an inch.
    Is it possible? Have you tried it? And if so, how.
    My only other alternative is to customize my own built from scratch wireform which I am not keen on.
    Thanks, Joel
    H.I.O.P.
    #2 83 days ago
    Knowing the game or seeing the pic would probably help. I have bent my own with pliers, but it was a small one on Star Trek to make the "Away Team" switch register accurately. I wanted to keep the original one stock in case adjustments didn't work anyway.
    https://pinside.com/pinball/forum/topic/star-trek-v161-bugs/page/7#post-4347306
    #3 83 days ago
    I would say you need to be very careful, since chrome can be fairly brittle.
    #4 83 days ago
    Something to consider might be if the wireform is chromed, it may mess up the finish. Also depending on where the bend is you may need to reweld if a weld breaks. If not overly concerned with the current finish of the wire, adding some heat may help ease the bend
    Ditto^^
    #5 83 days ago
    You can powdercoat if you chip, fairly inexpensive. I'd use some heat, bend to shape, then powdercoat it
    #6 83 days ago
    What game? If it's long enough you might be able to just move it over to the inlane if it's not one of the games that just has straight ends.
    Very slight bends can be made with pliers but as others noted, it's likely to mar the chrome finish.
    #7 83 days ago
    Can you loosen the screws holding wire form, re adjust it enough, and retighten?
    #8 82 days ago
    I actually want to have it powder coated eventually, so finish is not a concern.
    Just wondering if it is possible. Have to move the end about 1.5 inches over a run of about 8 inches./
    $ 64.00
    Lighting - Under Cabinet
    $ 9.99
    $ 24.25
    The MOD Couple
    $ 9.00
    $ 49.95
    pinballmod
    $ 17.95
    Pinball Photos
    $ 24.50
    £ 49.00
    PinballToys
    Flip N Out Pinball
    CzTV Mods
    $ 36.82
    Pinball-Mods.com
    $ 46.99
    Lee's Parts
    $ 48.00
    $ 209.99
    PinBoss Mods
    $ 34.00
    The MOD Couple
    $ 209.99
    $ 45.00
    $ 63.00
    $ 36.99
    Lee's Parts
    $ 14.00
    $ 48.00
