I brought a HGT back from the dead and I'm having a very frustrating issue.
Symptoms: When a coil fires the controlled lamps and GI will dim slightly. At random times a coil firing will reboot the game. Sometimes you can get 4 or 5 games in, sometimes it'll happen in the first few flips. I know at least the flippers and pops can cause the issue.
Troubleshooting already done: I've replaced the rectifier board and tried subbing in Alltek Solenoid board and MPU with no change. The problem persists with the controlled lamps and sound card unplugged. I've tried rebuilding every female connector that can't be ruled out (game still reboots even if the connector is unplugged). The power cord has been replaced. I've replaced the diodes on the flippers with no change and I don't really know where to go from here other than just starting to replace every diode on each coil but there are no other diode symptoms (no multiple / incorrect coils firing). Is there another power related area that might be suspect? Reflow the transformer? Wonky power switch? I've tried wiggling every connector that I thought suspect in case the vibration of the coils was causing it instead of power.
Edit: problem was an out of place, loose diode from a P.O. modification in the slam tilt circuit.
