(Topic ID: 287461)
Harlem Globetrotters MPU issue
By Woodingfleece
#1 3 years ago
This is my very first table and it was working great for the first week but all of a sudden the game stopped working.
I notice on the MPU the green LED flashes Once and then stops and all the lights come on but the game wont complete its boot up sequence.
I have ordered new fuses to swap those out to see if that helps.
Any one out there have any advice?
Thank you in advance
#2 3 years ago
You’re in the right place, and that’s a great machine. Welcome!
Could you post a picture of the mpu? Does it have the original battery on it?
Perhaps, with the machine off, you could disconnect and carefully re-seat the connectors.
#3 3 years ago
It does not have the original battery
The person I bought it from installed a vRam chip I believe is what he called it
I did carefully do that with all the connectors and still no luck
I also looked under the play field to see if anything was burnt out. I do not see any burn outs on any boards or any solenoids underneath
#4 3 years ago
Original MPU? Maybe try disconnecting the Top Left Connector (J1?) and then powering up. Any difference? I can sometimes get an MPU to fire up that way after a ghost reset I am chasing.
Another spot you might want to check for shorts that can cause an MPU reset are the light leads for your pop bumbers. Have had more than a few where the staple works out and the lead flops around and shorts...long shot. But I have had it happen on a Skateball, Paragon and Flash Gordon.
#5 3 years ago
If you do not have any corrosion related issues on the board, then probably your 6810 Ram at U7 is bad. You could try to reseat it. If that doesn't help, then replace it.
#6 3 years ago
Power it up while J1 is disconnected?
#7 3 years ago
I read that about the U7 somewhere else
Is it easy to take that Ram off of U7?
I have never done this before?
#8 3 years ago
Quoted from Woodingfleece:
You can carefully pry it out of the socket with a small screwdriver. Pry it out evenly to avoid bending the pins on the chip. Replace it carefully as well, to avoid bending the pins when you push it into the socket. Also, there is a notch at one end of the chip. Should also be a corresponding notch on the socket or circuit board so to orient the chip correctly.
#9 3 years ago
Ok I will try that as well
Forgot to mention that when it happened exactly
It happened like this
Turned on the machine, it booted up properly
Was able to put in 3players to play the game
I started to explain the games rules to my friends when I was done is when it died out on me. With the scores blank and then I tried turning off and on and it turned on but only had the 1 blink on the green led from this point on
Idk if this info will help anyone pinpoint things easier
Thank you all so much for your advice
3,000 (OBO)
Bay Shore, NY
$ 18.95
5,299 (OBO)
Grandview, MO
3,000 (Firm)
Lancaster, OH
$ 22.50
$ 12.00
$ 8.00
Third Coast Pinball
$ 10.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/harlem-globetrotters-mpu-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
