Need some help as I’m venturing into new area. Picked up a Harlem untested. Got home and would not power up in anyway. Replaced the two prong plug with a three prong plug and tried again. When I powered it on it blew the Q4 transistor on the solenoid board along with R17 and R18 resistors. It also blew the trace out from Q4 to pin 5 at J1. I checked schematics and it indicates these parts are linked to the out kicker solenoid. I replaced Q4, R17 and R18 and jumped a wire to replace trace from Q4. I also removed a wire off one of the legs of the out kicker solenoid thinking if that was a problem I would eliminate it. Powered on and Q4 blew again.
At this point thought I should see if anyone had any suggestions to next step.
