(Topic ID: 172459)
Harbor freight lift table slowly sinks
By jsa
2 years ago
  • 21 posts
  • 12 Pinsiders participating
  • Latest reply 2 years ago by Lamprey
    #1 2 years ago
    I've noticed that my harbor freight lift tank I use to move my pins slowly sinks. Has anyone had any experience with this? I've checked the release cable, it doesn't seem to be causing any tension.
    #2 2 years ago
    As with any hydraulic jack, the inner seals can give way and thus not hold pressure anymore.
    #3 2 years ago
    Mine never held correctly. There's a valve you can tighten but it only slowed the bleeding.
    #4 2 years ago
    Mine also would drift down
    I took it back and got a new one
    The new one also drifts down but it
    Takes a day or two compared to a couple of hours on the first
    #5 2 years ago
    Mine does the same, instructions say to bleed the system, haven't had time to do it.
    #6 2 years ago
    I had this problem with mine after about 5 years of heavy use.
    Turned out to be an issue with the handbrake lever line that you press to lower the table. I don't remember how I fixed it but it was easy. Something was loose. So follow that whole line from handbrake to hydraulic and see.
    Another 7-8 years of heavy use since then and no problems. Except I need to replace the wheels.
    #7 2 years ago
    This has had the problem from the moment I got it this past summer. The odd part is that sometimes it seems like the problem goes away, then it returns.
    Does anyone know how to bleed it?
    #8 2 years ago
    Having same issue myself would love to know the fix I'm on my second one
    #9 2 years ago
    The way I bleed any hydraulic jack is to hold the release while pushing down on the jack lever, then let go of the release before letting up on the up lever. A few times of doing this is enough to get any air out.
    #10 2 years ago
    The reason it won't hold is because there is air in the system. There are instructions in the manual and on the side of the jack on how to bleed it. Basically, extend the Jack to its full open position, remove the red plug, slowly lower the Jack half way, add hydraulic fluid so that its full, put plug back on.
    #11 2 years ago
    It's from Harbor Freight, you are surprised?
    #12 2 years ago
    Quoted from Lermods:
    My instructions that came with the table were a folded piece of paper that made reference to bleeding the system, but with no specific instructions (at least in English). Do you know how they deal with the fact that if you raise it fully, then lower it half way, it's sinking on you while you pop the red plug? Sounds like a cat juggling procedure.
    #14 2 years ago
    There is a locking rail on it if you need to hold it up. It has a couple of notches on it for different heights.
    #15 2 years ago
    Ok, I ordered some hydraulic fluid and we'll get this guy fixed. Do I need a pump or special funnel to get it in, or just pour?
    #16 2 years ago
    Uhhh...so you didn't bother checking the handbrake lever line? It could just be that. Happened to me. Exact same issue and had nothing to do with hydraulic fluid.
    #17 2 years ago
    I have the same issue! Hopefully I can get it fixed following these instructions
    #18 2 years ago
    Quoted from CrazyLevi:
    My conections are all tight. Its an air issue. Either that or its just junk, which may be the case since its harbor freight.
    #19 2 years ago
    I checked my cable, it's not too tight.
    #20 2 years ago
    Mine does the same. I find that if I pump it up again, it holds.
    #21 2 years ago
    The lift is very finicky. If it's slowly lowering, then it's probably air. Follow the bleed instructions and, hopefully, it'll work.
    I have a weird scenario with mine where I can't lift anything unless the handle is in the right position (I modified mine), but it doesn't make any sense at all as there is no tension on the release leaver line/cable. *shrug*
    $ 79.00
    Flip N Out Pinball
    Metal-Mods
    € 95.00
    FlipperLED
    $ 28.00
    $ 53.00
    $ 79.00
    $ 18.99
    Flashinstinct
    $ 239.00
    Tilttopper
    $ 24.95
    $ 8,999.00
    Operation Pinball
    3D MODS
    $ 7.95
    Apparel - Unisex
    Pinball Wheezer
    Filament Printing
    Metal-Mods
    $ 79.95
