(Topic ID: 298900)
Happy Clown help
By Bakerman
2 years ago
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by undrdog
#1 2 years ago
Hi, I am trying to work through a few issues on my Happy Clown. The Add Reply Unit coil seems to lock on when it activates. The coil FF also locks on at the same time. However, on my Happy Clown schematic there is no mention of coil FF. Am I missing something or is the schematic incorrect. The FF coil is located in the backbox, just to the left of the N relay. Any help would be great as this one is driving me mad!
Cheers,
Mike
#2 2 years ago
Bump. Any EM gurus out there?
#3 2 years ago
The Replay Unit can advance due to a coin drop, high score and match. Does it lock on in all three cases? If you disable the Match feature and remove all of the high score replay adjustment plugs does it still lock on?
I don't know what to tell you about your FF relay. The reference photo at PBResource doesn't show it:
http://pbresource.com/pfplayfEM.htm - search for Happy Clown, then Ref Back Box
/Mark
#4 2 years ago
Maybe the FF relay is related to a foreign pricing scheme.
.................David Marston
#5 2 years ago
Thanks for the ideas.
Quoted from MarkG:
Yes and Yes.
I think that it must be something specific to overseas markets. I'll try and work it out, but it is not easy without a diagram.
#6 2 years ago
I can send you a pic of the schematic ff coil section if that helps
#7 2 years ago
If you can, please post images here. Please post FF coil in the wiring portion of the schematic, plus FF on the relay list, and any switches controlled by FF that you've happened to find on the schematic.
#8 2 years ago
Quoted from Paja:
That would be great if you could. I have pretty much worked it out by myself but I would love to see if I did it right and have it for future reference. It must have only been fitted to export machines.
#9 2 years ago
Bakerman I'm sorting out which rubbers are correct on the Happy Clown I just got.
On the center C-L-O-W-N unit, does yours have one large rubber that spans the entire back of the unit covering all of the back posts? Mine came with two smaller rings, one left and one right, overlapping at the back center.
#10 2 years ago
Hi, I have not been able to find the photos my Happy Clown, but I am sure that I it should have one long rubber and not two shorter over lapping ones.
#11 2 years ago
Thanks.
1 year later
#12 1 year ago
This is an old post, but my Happy Clown also came with two overlapping rubber rings, one from each side
Alberto
#13 1 year ago
Peruman
Cabinet Parts
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/happy-clown-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
