New! Dark mode!
(Topic ID: 275448)
Hanging a playfield
By Stosel
68 days ago
  • 22 posts
  • 13 Pinsiders participating
  • Latest reply 64 days ago by midcoastsurf
    There have been 40 images uploaded to this topic. (View topic image gallery).
    #1 68 days ago
    I have an unpopulated playfield that I would like to use as wall art.
    What is the best way to hang these? I was thinking of running a picture wire through some of the holes at the top and using pictures hooks, but I don't know if this would be the best method.
    Also, is it ok for drywall, or do I need to hand it from studs?
    #2 68 days ago
    I have been using the 7/8 rubber post sleeves and sticking them into one of the through holes at the top, then screwing through the post rubber. It compresses down a bit, and puts pressure on the through hole, holding the playfield in place.
    This method does not damage the playfield, which is good if you are using playfield that may later be installed in games.
    https://www.pinballlife.com/78-black-rubber-post-sleeve.html
    #3 68 days ago
    I'll be hanging this one soon will let you know
    #4 68 days ago
    Quoted from Defender:
    Thank you, I was worried about the picture wire potentially doing damage.
    #5 68 days ago
    I have half a dozen hanging on my wall in my game room. All of them are hung the same way. I use drywall screws that go through an already existing hole in the PF at each corner. Hangs flat against the wall and isn't coming off unless you go crazy trying to pull it off the wall.
    https://www.lowes.com/pd/Grip-Rite-6-x-1-5-8-in-Bugle-Coarse-Thread-Drywall-Screws-1-lb/4744171?cm_mmc=shp-_-c-_-prd-_-hdw-_-google-_-lia-_-126-_-nailsandscrews-_-4744171-_-0&placeholder=null&gclid=EAIaIQobChMI4Nv76rql6wIV1ZFbCh2EjQ5VEAYYAiABEgJG8fD_BwE&gclsrc=aw.ds
    #6 68 days ago
    I would use string instead of wire, but either wold work, IMHO!
    #7 68 days ago
    Quoted from 85vett:
    I like this idea so it lays flat. I have a bunch classic stern playfields I am going to hang in my new gameroom and I will probably do it this way.
    #8 68 days ago
    Grabbed some pictures to help visualize how it turns out. I thought I used drywall screws but it looks like I just used some deck screws I had laying around already when we moved. Should have used drywall but even those hold it nice and tight against the wall.
    Boxed out the screw locations to help show them.
    #9 68 days ago
    O'man...., where do I begin? Lots of old pictures and I've certainly tweaked the collection since then but you'll get the idea.
    John
    Black Knight pf (resized).jpgCeiling, furture spa volcano,.. (resized).jpgDolphin NOS pf (resized).jpgHercules 74 inches x 38 inches (resized).jpgIMG_0015 (resized).JPGIMG_0016 (resized).JPGIMG_0097 (resized).JPGIMG_0102 (resized).JPGIMG_0103 (resized).JPGIMG_0104 (resized).JPGIMG_0105 (resized).JPGIMG_0107 (resized).JPGIMG_0108 (resized).JPGIMG_0109 (resized).JPGIMG_0110 (resized).JPGIMG_0112 (resized).JPGIMG_0113 (resized).JPGIMG_0114 (resized).JPGIMG_0115 (resized).JPGIMG_0116 (resized).JPGIMG_0117 (resized).JPGIMG_0118 (resized).JPGIMG_0119 (resized).JPGIMG_0120 (resized).JPGIMG_0121 (resized).JPGIMG_0122 (resized).JPGIMG_0123 (resized).JPGIMG_0124 (resized).JPGIMG_0127 (resized).JPGIMG_0128 (resized).JPGIMG_0129 (resized).JPGIMG_0130 (resized).JPG
    #10 68 days ago
    Quoted from Dayhuff:
    John
    Now THAT"S a collection of PF's! What I wouldn't do for a flatbed scanner big enough for a PF and about 2-3 days at your house. I have a sick hobby of enjoying redrawing PF's for virtual pinball and wall art overlays (thus how my batman DE PF happened).
    #11 68 days ago
    Speechless over here on that
    #12 68 days ago
    John
    [quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
    Very Impressive! Thanks for sharing!
    #13 68 days ago
    Screwed directly to drywall unless I hit a stud by chance...
    #14 68 days ago
    John
    Umm wow, that is amazing
    Quoted from 85vett:
    Boxed out the screw locations to help show them.[quoted image][quoted image][quoted image]
    Thank you! I think I am going to go with this method. Gotta pick up some drywall screws tomorrow.
    #15 68 days ago
    I hung mine with a wire across the back. Pick up some battery operated Angle Lights from Amazon ($8). I used little pieces of duct tape to put them behind the inserts. Looks great.
    #16 68 days ago
    I dont like seeing the heads of the screws when looking at the playfields so I used some simple picture frame brackets. One on each of the top two corners and then mounted to the wall using low profile head screws. Playfield finishes basically flush with no hardware exposed and only two small holes in the wall. You could try only one bracket but the weight might be too much over time.
    #17 67 days ago
    Quoted from Mattyk:
    I used a set of twinkling or chaser led lights and some hot glue.
    #18 67 days ago
    Wall art is up! Used hooks with a safety wire in case.
    #19 66 days ago
    Quoted from gdonovan:
    Awesome! I was going to ask for a pic of the backside of the pf before you hung it up (too late .
    How else is everyone lighting up their playfields on the wall? Anyone programming an attract mode with arduino board?
    #20 66 days ago
    Quoted from midcoastsurf:
    I use constant-on 5v string lights. However, I have toyed with this idea, and thought it would be freakin' rad. Sadly, I don't know Arduino well enough.
    #21 64 days ago
    Will this do?
    #22 64 days ago
    Will this do?
    Thanks for sharing!
    $ 9.99
    $ 64.00
    $ 259.99
    $ 63.29
    Pinball-Mods.com
    $ 86.00
    The MOD Couple
    $ 70.00
    $ 5.00
    $ 229.99
    $ 28.00
    Pin Monk
    $ 495.00
    MI Pinball Refinery
    Pinball Pro
    $ 69.99
    $ 29.99
    $ 119.99
    $ 69.99
    $ 7.00
    $ 40.00
    Pinfarmer Mods
    $ 209.99
    $ 150.00
    $ 29.99
    Lee's Parts
    Arcade Upkeep
    $ 99.95
    pinballmod
