Here are a few handy pinball repair tips from the person who serviced my WH2o before I got it.
Stripped hole for wood screw: Squirt a little silicone caulking in the hole then jam the screw in. Then add a little more on top for good measure.
Broken Wire: Twist the two wires together and smear some silicone caulking all over it and let it dry.
Missing lock nut: just use a regular nut covered in silicone caulking.
Missing hex nut for coil stop: jam a piece of wood into the hole where the screw would go and fill with silicone caulking.
Broken off screw flush with surface: Cover with silicone caulking. It doesn't do anything but at least you can't see the broken screw.
Broken plastics: Turn the broken plastic over and use a popsicle stick and silicone caulking to repair the crack.
Broken Ramp: Silicone caulking.
These and other amazing repair tips were found while I shopped out my machine the other night....I hope they all come in handy.
I've got to get some Silicone caulking for my tool bag...I can't believe I've gone this long without it.
This is not an April fools joke....unbelievably it's all true.
