Has anyone used hammer tone spray paint - successfully?
I am trying to paint an old set of legs with no luck, is there a trick to doing it right?
I soaked the legs in CLR to remove the rust, rinsed them, gave them a light sanding.
I then primed them with Rust-oleum clean metal primer (light gray/white).
24 hours later I sprayed them with Rust-oleum Hammered (silver/gray) from about 12" away, but the "hammertone" effect did not appear, it just looked like regular silver/gray sraypaint.
So about 48 hours later I sprayed a few more coats this time very close with only minimal "hammertone" effect, you have to look at them closely to see it.
Any advice?
