So onto the bracket you will have to remove the wire form above the snake. Also the plastics around the snake and captive ball. Then I trace the captive ball plastic onto my metal. Make sure you don't cover the window to the captive balls. Then leave 3 inches in both directions. Then rough cut it with snips. Was going to go with a two post on a pin system. Thought I could make it move with a wire behind the captive ball switch. Well gave up on that at this time.
