Been working on a few issues for a while. Still problems even with code update. Want to see if anyone/everyone else is having these issues.
Trough eject - sucks! Only ejects the ball about 1/2-1/3 the time. Have already taken it apart. Made sure nothing binding. It clicks. Tries to push the ball up, but falls right back down. Sometimes works absolutely perfect, but about 1/2 the time it doesn’t. Have adjusted the trough power in all different options but still same issue. This now leads to the next big issue.
Ball doesn’t eject and now causes problems in the game! So the trough eject tries several times, but after 5 times, it ends your turn and goes to the next player. Even during ball save timers. So you launch a ball, after a few flips it goes SDTM and then pops up “ball save”. The trough tries several times to pop the ball up but it doesn’t work. The turn ends and then on to the next player.
Sometimes when the ball drops below the pumpkin from the 2nd playfield, it never comes out to the right flipper. The ball stays below in the subway and after a little bit the machines does it’s ball search. Doesn’t find it and then turn is over. When the next player comes up to play, a ball is sent into the shooter lane. Then out of the blue, the ball that was below in the subway comes out and then you get a multiball when you’re not supposed to. I’ve check the subway and all switches and everything is registering.
Even after the latest code update I’m still having these same issues. Are these being addressed by Spooky at all? It sucks to be sitting on a $9k paperweight that sucks to play because more times than not there are these issues.
