Hi all, so I'm encountering a couple of issues
Issue #1; When I first switched the machine on, the audio sounded really muffled and overly bassey.
Before I switched on, I made sure that everything on the subwoofer controlls inside the cab weren't mazed out (there don't appear to be markings on the controls though).
At one point I disconnected the hdmi lead from the screen and plugged back in; this sorted my issue; very clear sound (maybe the sound was only coming out of the sub before that?)
So I went in to tweak the sub knobs a bit to add a little more bass back in; same issue returned - muffly bassey sound. Un-replugging the hdmi cable didn't fix it.
Any ideas?
Issue #2; the screen looks washed out, so I tried using the buttons on the screen to adjust, but brightness and contrast don't really seem to do much? - I also set Gamma to ON
issue #3; now when switching on, I juat get a grey Utilty screen - now what? - can I just plug a keyboard to select exit?....
Issue #4; centre ramp bank of drop targets. Twice now, the left d target became stuck down and the 2nd and third not going down enough.
Upon lifting the PF I discovered that this was because the bottom left target had slipped out of the metal part which pushes the targets up when the coil fires to reset - this meane that the metal part then couldn't go down far enough to bring the center and right targets down.
Solved by popping the left target back in to place.
Only thing is, it's happened twice now ; any ideas on how ro stop that happening in future?; seems maybe the metal part which pushes the targets up has a little too much play in it which can let the left target slip out.
Many thanks for your help guys
