Quoted from runpaulone:Can anyone help with the plunger issue I have? Just purchased this a week ago, got it set up and plunger does not hit the ball anywhere near well enough to get it moving. Should the plunger hit the ball or the metal object resting on it? Sorry for my lack or knowledge on proper terminology. Spring seems very weak compared to other pins I just bought.
Thank you. -Paul
The rubber-covered end of your shooter rod should be directly in the center of those two metal forks barely not touching the ball at rest.
Those two metal forks are the auto-launcher, and should never touch the shooter rod.
It's like your playfield is not sitting in the cabinet correctly and/or the shooter rod assembly is skewed way too far to the left.
Can you take another picture zoomed out a bit but from the same overhead angle so we can see that whole corner of the cabinet, especially how the playfield hooks are in the lock bar bracket. We need to see more of that area.
RussM
