Quoted from Rdoyle1978:This reminds me - the mode hole shot on the Williams IJ has a very similar issue. The ultimate fix for mine was to remove the scoop shroud entirely and add the PinBits deadening foam. That stuff was magic. I’m not sure removing the shroud is an option here, but I sure as heck think it worth trying with the foam.
All that said, I dont have too many issues with scoop rejects - my issue is much more consistently with the center ramp shots bouncing off the diverter (I think that’s what is happening) and then immediately SDTM. That and when I get a slightly weaker shot up the ramp and the ball just stops on the upper playfield. I usually have to tilt to shake it free. I need to figure that out.
Drop dead foam is amazing ( still have a couple strips hoarded in my stash) . Hard to find anymore..( believe Pinbits is gone or something) there were similiar products listed in here some time back as well.
Doesn't really work for this application ( I tried) due to the spot where the ball hits the scoop, along with its shape.
Bending the original back down after its been smacked up definitely helped. The permanent fix is replacing the "scoop" to a "deflector", acting simply like a backboard...sends the ball into the hole.
Also have to pay attention to the mylar strip around the protector. Can act as a ramp if it's on the metal, instead of just around it.....the little things...
