Is their a tried & true method of tweaking a pin with playing field ball traps. Had to disable the tilt warning device as only way to dislodge the ball was shake the crap out of the pin.
Quoted from VandyOne:Is their a tried & true method of tweaking a pin with playing field ball traps. Had to disable the tilt warning device as only way to dislodge the ball was shake the crap out of the pin.
Where are you seeing a trap on Halloween? Occasionally any pin will get a ball hung up that's corrected with a soft nudge. Look at where the hang up is, and "figure it out". Different rubber? Mylar? There's -usually- a solution.
Not a -single- tried and true method. But yeah, anything is fixable. Care to add some more details about what’s happening so we can help you?
Thanks for the response and in order of frequency
1. Upper house playing field to left of center ramp
2.Hole to drop ball back to start lane at tip of knife
3. Clear plastic cover to right of 3 drop targets on n main playing field where it connects to ramp to Sanitarium
4 Top of both feed lanes on main flippers where metal merges with playing field
Another experience Pinside member suggested I check leveling. Checked level & it’s center of the bubble at both top & bottom. Having said that I love the pin & can live with it if its just a gremlin with new games
This page was printed from https://pinside.com/pinball/forum/topic/halloween-ce-ball-traps- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
