DSC00234.JPGyeah i have a few rolls of #3 "solder wick" and " techspray "for me and the tiny stuff but it depends on the job.
same with temp :
Quoted from Deez:recommend a decent braid? Also, what temperature do you typically set your iron to when using it?
my PACE tip selection book always recommends "for most" general stuff starting at 600 and adjusting up. well it pretty much stays at 650 for most of my bench soldering but it depends on the tip, the size of trace, the component and just experience with your equipment. mine is a digital PACE MBT unit and you can put in factory offset adjustments of say 47 if you have some big crazy surface mount tip on there.
De soldering temp is usually around 690 maybe a tad higher.
Ideally you really always want to use the lowest temp that will give you the perfect joint if your a little bit higher for a trace you will find out, but to long with a low temp is not good either.
Here is another IC puller that works good for ROMS and dips, i gave up on the screw driver.
back to the topic: the video was great i enjoyed the stalactites and stalagmites thanks for finding it. Endproduct
yeah i am going to pick up a set may work good for a plugged tip as well. Just another one of those extra techniques and tools that no one really talks about maybe a real good thing to keep in the ROAD bag.
