(Topic ID: 260049)
Half-Wave Rectifiying a Coin Lockout Coil
By leckmeck
  • 26 posts
  • 7 Pinsiders participating
  • Latest reply 4 years ago by leckmeck
#1 4 years ago
I’m working on a Gottlieb Atlantis. It’s an EM, but what I’m trying to do is more in the realm of an SS technician’s expertise, so I figured this would be a good forum for my question.
The coin lockout coil on Gottlieb EMs is nearly continuous duty. It only turns off when the score motor is turning. Because it’s on for such long periods of time, it gets very toasty. The crispy brown spot on the underneath of the lower end of the playfield is the long-term result of this heat. At this advanced age in these games’ life, the mechanism does not perform well. It usually makes a racket—vibrating like hell from metal fatigue and other factors—and most mechanical adjustments do little to dampen the noise.
So I picked up a 220-ohm A-16890 coil from PBR and want to correctly half-wave rectify it, making the coin lockout mechanism reliably functional and quiet. I’m following the instructions Clay Harrell wrote on Pinrepair.com for fixing tired Hold and Game Over relays. I was able to use two IN4004 diodes to get the half-wave rectification, but the ripple is bad and the coil struggles to pull in the actuating plate. Clay’s instructions mention that Gottlieb often used a capacitor and resistor to smoothen the ripple.
SchematicSchematic
So I picked up a couple of capacitors and resistors from Mouser. Here is the part number, description, and photo of the capacitor:
Aluminum Electrolytic Capacitors - Axial Leaded Aluminum Electrolytic Capacitors - Axial Leaded 50uF 50V Custom P/N
CapacitorCapacitor
Here is the same info for the resistor:
WSC00026R000FEB Wirewound Resistors - SMD Wirewound Resistors - SMD 2watts 6ohms 1%
ResistorResistor
Then here is how my coin lockout mechanism is currently wired with the diodes and A-16890:
Coin Lockout MechanismCoin Lockout Mechanism
Can an expert in here advise me how I can marry the capacitor, resistor, diodes, and coil? Also, do I have the right capacitor and resistor?
Thanks very much.
#2 4 years ago
Admire your efforts. I just cut the coil off the coin door, it is obsolete unless:
Its going on location
You wish to keep it original
#3 4 years ago
Quoted from phil-lee:
I used to just disconnect the noisy ones, but lately I’ve been making an effort to get my restored games fully coin-operable, including the coin lockout. Whatever the reason, I find it very satisfying. Just strolling through my game room with everything off, I’ll drop a random quarter just to hear it clatter into the coin return.
#4 4 years ago
Incidentally, I tried to use just a capacitor to smoothen the ripple. It worked for about five minutes, then the capacitor burst and gassed out. I’m guessing the resistor is necessary. And maybe I need more than the 6-watt, 2-ohm resistor that I bought. Line voltage is higher than it was 40 years ago, so the 24-VAC circuit is actually measuring at nearly 30 VAC. Thoughts on the resistor?
Anyhow, just looking for some expert guidance. I’d like to learn more about DC power; this has been a fun exercise.
#5 4 years ago
Quoted from leckmeck:
There is an easier way to get this done. If you get a small bridge rectifier like the one I linked. Wrap outside leads around the coil lugs and solder. The wires that were removed from the coil, solder them to the inside leads and shrink wrap. Your done in 5 minutes or less. Now your full wave rectified and wont need to worry about the small ripple that's left. It will look cleaner too.
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwjXn5GTr5DnAhUR28AKHT_NDD0YABAMGgJpbQ&ohost=www.google.com&cid=CAESQeD2qqi4oEwdTbjNjjfuU4gc2ukOxXC9H1DjzDJZAhqanYKbb-ivJfGCaNn8ft7gC2gY1DJgXE7miBMxgc583Uvc&sig=AOD64_1YlCA4SEn9C4bNciobEvEAN3igig&ctype=5&q=&ved=2ahUKEwiI64iTr5DnAhXXF80KHVh4Ac0Q9aACegQICxA7&adurl=
#7 4 years ago
Quoted from GRUMPY:
If the voltage is a bit higher then it should be then you can use this one instead.
Thanks for the links. I do like how unobtrusive the bridge rectifier would look.
Because the coil turns off every time the motor turns, does the bridge rectifier need a diode to protect it from backwards voltage surge?
#8 4 years ago
Incidentally, I tried to use just a capacitor to smoothen the ripple. It worked for about five minutes, then the capacitor burst and gassed out...
By chance did you install the capacitor backwards? It is polarized.
#9 4 years ago
A spike will affect solid state devices and be a concern but I don't believe this is an issue on an EM. If you like you can place a diode across the coil lugs with the band facing the notched corner of the bridge rectifier as this is the positive lead of the bridge. After the coil is powered for 20-30 minutes, check the temperature with your hand, if its too warm you will need to add a dropping resistor in series with the coil. Start with something @ 100 ohm 5 watt ceramic resistor to lower the current draw and heat. Shoot for @ 100 -150 degrees.
#10 4 years ago
Quoted from mbwalker:
I think I had it right. The longer lead off the end with the CDE arrow (I think that is cathode) was connected to the same lug as the banded diode.
Was that right?
#11 4 years ago
Was that right?
The CDE arrow looks like it's pointing to the negative leg of the capacitor, so it was likely installed backwards. The half channel around the right side of your axial capacitor picture indicates the positive leg.
#12 4 years ago
Quoted from Quench:
Thanks. You’re confirming what I just read in the technical specification PDF for this capacitor. Man, how hard is it for them to just print a minus or negative sign on the dang thing itself?!
Capacitor SpecsCapacitor Specs
#13 4 years ago
I appreciate @GRUMPY’s advice on using a bridge rectifier, and I’ll try it next time I do this. For this Atlantis, however, I’d like to try utilizing the parts I have on hand. This drawing is how I intend to wire them together. Does it look correct according to the schematic?
Proposed WiringProposed Wiring
Gottlieb SchematicGottlieb Schematic
#14 4 years ago
Looks correct to me.
#15 4 years ago
It’s not pretty, but it works. I left it energized for a long time and there’s no heat on the coil or capacitor.
Next time I’ll do the bridge.
Thanks for the counsel, y’all.
#16 4 years ago
Invoice is in the mail.
Joking aside, I'd probably secure things a little better. The surface mount resistor might not (won't) fair very well with vibration. Something like this, then run a wire up to the solenoid. And just get a leaded resistor.
Looking at the connection below...I don't think it will last long. At a minimum, run the wire parallel to the resistor lead, not perpendicular.
Not nit-picking, just thinking long term. Plus you definitely don't want a 50V wire breaking loose!
#17 4 years ago
Then you might not need the resistor then. Removing it may stabilize the wire better.
#18 4 years ago
I read that bit from Clay about replacing those always on relay coils on a quick draw. I don’t understand the purpose of the diode across the coil lugs. Looks to me that it would work with just the diode and resistor in series. Can someone explain?
#19 4 years ago
Quoted from sysprog:
When the magnetic field in the coil collapses, a reverse voltage will be generated. The diode across the coil will snub that voltage by turning on. Normally, the diode is off then only turns on when the coil shuts off. Not sure how important it is in an EM (very important in a solid state pin since they don't tolerate a reverse voltage), but likely installed as a precaution.
Make sense?
#20 4 years ago
What is the name for that thing? Some kind of mounting board would be great for securing and compartmentalizing all these little components.
I wish I could find one. Mouser has exactly one (!) stocked option for this rating of resistor. Is there another source I should consider?
Thanks for the feedback. I don’t mind the criticism. I gave the resistor/diode choo-choo train a couple of rude yanks and it doesn’t yield. This stuff is on the coin door, where it’s pretty sleepy. Maybe if I put the game on location and have delinquents banging on the coin door!
#21 4 years ago
Google 'terminal lug mounting strip', that should get you started. Amazon has them, but they are around $7-$10 w/Prime. Ebay or a surplus store might be better. I was thinking you could maybe use a screw already in the PF to mount (but don't use that lug for parts then). Coin door - Ah OK. Better, but I'd still go the terminal strip route - then you will never have to worry about it again. Boy, I'd hate to see the 48V (or 24V?) wire come loose and fry something. G.P.E here on pinside might have them. It's kinda old school nowadays to use that style.
I know an easy place to probably find the resistor...me! You'll have to give me a few days to check. Might be 2-3 of resistors instead of one, but I should be able get you close. PM me your address and I'll shoot you the resistors if I can. Still 6 ohm, 2W, right?
#22 4 years ago
Looks like I can get you pretty close to the desired resistance a couple of different ways...
Won't be able to send out until this Sat or maybe early next week, if that's OK.
#23 4 years ago
Make sense?
Yes thank you, I was aware of the need for diodes on SS coils, didn’t really see the need on an EM.
#24 4 years ago
Don't get too hung up on that 6 ohm value. 5.6, 6.8, or 6.2 if you go down to 5% or 1% tolerance, and that's without even worrying about math.
#25 4 years ago
On EMs, that diode lengthens the life of the bridge rectifier.
#26 4 years ago
I bought a pack of these and will use it to stabilize everything.
Then NEXT time I will just use a bridge rectifier.
When I first got into pinball ten years ago, I kept cooking transistors on the driver board for a System 1 game. I swore off SS games and stayed with EMs. This has been a good learning experience.
Won't be able to send out until this Sat or maybe early next week, if that's OK.[quoted image]
I’m in no hurry. I’ll PM my address to you. Thanks!
Lincoln, MI
Space Coast Pinball
$ 1.00
Pinball Alley
$ 12.00
This page was printed from https://pinside.com/pinball/forum/topic/half-wave-rectifiying-a-coin-lockout-coil-on-an-em and we tried optimising it for printing. Some page elements may have been deliberately hidden.
