Well at least all my GI lighting is working now. Williams Jokerz! I'm working on, getting everything back together after a playfield restore. While I'm happy all the bulbs are firing now, I obviously don't like that the left side is dim. Looks like I'm getting half voltage (3v vs 6v) on the dim side. I jumpered one of the right bulbs to the left side with alligator clips, the whole left side brightened right up.
Rather than trace the issue (probably a weak solder joint), is it a hack if I want to simply solder a permanent jumper over to the left side? I mean it's doing the same thing, all the GI is basically a christmas light string.
