gorgar switch matrix.pngHalf of my Gorgar switch column 5 (the green-black wire) has quit working. Switch 33,34, and 35 do not work, but switch 36-40 work just fine. I have checked all the wire attachments to the all the switches in the column, and they seem okay. Nothing disconnected or weakly soldered.
Now I am a complete idiot with electricity. But I figured that if I ran a jumper from one of the green-black wire switch connections up stream that I know is working, to one of the switches downstream that is not working, then this jumper should bypass the troublespot and allow the downstream switch to work again. This did not happen. I tried all permutations, connecting each working switch to each nonworking switch, an never got one to work. I'm guessing this concept is flawed, but if it is, how else can I trace down the problem? Any help would be greatly appreciated.
