(Topic ID: 190898)
Guns n' Roses Wont Boot
By 1iblind
2 years ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by terryb
#1 2 years ago
I'm working on GnR and all that happens is the GI comes on and it makes weird sounds. Fuses F1 and F2 also blow but not right away. They take 30+ seconds to glow red and blow. I'm getting good voltage to the board and out of the board. DB1 and all caps are good. The board has also been tested and is working good in another game. When I disconnect CN6 the fuses don't blow. I'm stumped.
#2 2 years ago
Still can't figure this out bump.
#3 2 years ago
I'm stumped bump....
#4 2 years ago
I don't have an answer for you, but I'll bump this in hopes that someone on here will help you...GL
#5 2 years ago
If it's F1 and F2 on the power supply board then your 5 volt fuses are blowing, which would keep the cpu from booting. Test DB1 for a short.
#6 2 years ago
Quoted from terryb:
I tested DB1 and it's good. The power supply works fine in another game.
#7 2 years ago
Pull all of the connectors that carry 5 volts to other parts of the game. See if the fuses blow. If not then add the connectors back one at a time.
#8 2 years ago
Quoted from terryb:
The fuses don't blow when CN6 (on the power supply) is disconnected. Instead of disconnecting CN6 I pulled CN17 from the CPU and CN4 from the Sound Board. Even with both of those (CN17 and CN4) disconnected the game still blows the fuses. CN17 and CN4 are the only ones that CN6 carries the 5v to. Do you have any other advice on what I might be able to try? Thanks.
#9 2 years ago
Game off, CN6, CN1 and CN4 disconnected. Check continuity from one of the 5V pins on CN6 to ground.
Trade
Machine - For Trade
Cinnaminson, NJ
Yorktown Parts and Equip
$ 24.95
PinSound
