Quoted from Gomer:Is there a trick to opening the backbox on the LE? I unlocked it, usually with backglass you pull up and it sort of goes into the cabinet a bit then you can tip the bottom out. With this machine, I am getting no movement on the right side of the glass at all, and a little bit of up/down movement on the right.
Related side question, anybody try to install the art blades yet? By the looks of it the whole playfield needs to come out. I found a couple of wire jumpers to detatch, but there are even more somewhere in that big bundle of cabling running through the middle, which is why I was trying to get into the backbox
Check the torx bolts on either side of the license plate at the top. After I installed Pinwoofer, if I tighten down the left one, it presses on the translite glass and it wont come out anymore, so I leave it a little loose. Do you have a pinwoofer? Regardless, Maybe yours is tightened down and preventing the glass from moving.
Art blades installed, wet method, no removing playfield here... used generous amounts of soapy water on them. Allows to drop/slide into place (like protectors would be done) and still be able to adjust and move around and then to work the bubbles out too and when they dry they look great. I couldnt imagine doing them dry.
