I have been working on fixing some problems with my GnR pm. I have fixed pretty much everything, except when the game starts, it is loading 2 balls in. Every ball after that is working correctly. My FORWARD/REVERSE and Step buttons are not working so I am not sure if it is a audit or adjustment that was accidentally set. I have ordered a new button for each so that I can try to put things back to normal.
The sensor for the solenoid for loading seems to be working so I do not think this is an issue. The solenoid that moves the gate to allow balls to move to be loaded seems to be working fine too, maybe it is a bit sloppy (I don't know how it should be normally functioning).
Does anyone know why this would be happening?
Added over 4 years ago:I have been working on fixing some problems with my GnR pm. I have fixed pretty much everything, except when the game starts, it is loading 2 balls in. Every ball after that is working correctly. My FORWARD/REVERSE button is not working so I am not sure if it is a audit or adjustment that was accidentally set. I have ordered a new button so that I can try to put things back to normal.
I can still use my step button to go through Diagnostics, because my FORWARD/REVERSE is broken in the diagnostics position, but my Step button works. And since my coin slot assembly doesn't work I had always played the game on free play, I think the game got (accidentally) reset so I must pay to play, but since I cannot go into Audits and Adjustments, I cannot change to free play.
I have been playing by giving myself Service Tokens in the Diagnostics as a little work around for now. Maybe this is a bug with playing Service Token games?
The second ball sensor from the left is not working which might be an issue? But I don't understand why it would be causing this issue.
The only other sensor that is not working is the first one on the R ramp.
