(Topic ID: 35209)
Guns N' Roses Mods
By xsonics2k2
8 years ago
  • 340 posts
  • 94 Pinsiders participating
  • Latest reply 1 year ago by Coindork
  • Topic is favorited by 53 Pinsiders
There have been 125 images uploaded to this topic. (View topic image gallery).
There are 340 posts in this topic. You are on page 7 of 7.
#301 4 years ago
Quoted from Coindork:
Oh man, thats a bummer. If you really want one let me know, I could always order another one and ship it to you personally.
thx for your kind offer, but i think the shipping costs will be too high...
i got a couple pieces of massive copper lying around, maybe i do something with those....
#302 4 years ago
Quoted from DorkVonWaterfall:
No worries. If you do something with the copper, be sure to post pictures
4 months later
#303 3 years ago
Which version of ColorDMD looks better on GNR, LCD or LED?
#304 3 years ago
Quoted from xsonics2k2:
I switched from the LCD to LED version, so I wouldn't have to lower the speaker panel every-time I wanted to get into the backbox. LED looks awesome in it too.
#305 3 years ago
That's good to know jints, I think I'll go with the LED option.
2 months later
#306 3 years ago
I have done my Mods for GNR
Had the G ramp wire form powdercoated yellow, the R ramp wire form in red.
Then the main ramp and VUK in gun metal grey - funny enough the ball flies up there now, may solve the problem of not being property aligned
Changed the pop bumper caps to green to off set the extra yellow and red.
Stripped the mylar off the playfield and polished
Now need to find the extended plastic set with the "welcome to the jungle" plastic back behind the rear ramp.
#307 3 years ago
Really like the color matching wire forms!
#308 3 years ago
red and green pop bumper caps look so much better on this game then just the ugly yellow.
#309 3 years ago
so how much belt sanding did you have to do exactly, and is grinding area visible?
9 months later
#310 2 years ago
Have any of you guys lit the Pinbits back panel with a cold cathode tube? I tried and failed. The parts that need to be lit are 18" from the one rose to the other. I ordered a kit that has 2 12" lights and it's not enough. Those lights only cast out light directly in front of or behind the bulb, the light doesn't travel. The longest cold cathode tube I can find is 15"
4 weeks later
-1
#311 2 years ago
Quoted from pindude80:
I used an led light strip. Worked great
#312 2 years ago
Quoted from adams_arcade:
That's what I ended up using, it's ok. You can see the individual leds on the strip behind the roses and it doesn't light evenly. I placed the strip in the center, but if I had it to do again I would place the strip a little below center since you don't really don't see much of the top of it anyway, but none the less it looks way better than the factory plain piece of black plastic
#313 2 years ago
I found a proto type snake and added to mine. It look scary real!!
#314 2 years ago
Where did you find the snake????
#315 2 years ago
Quoted from allsportdvd:
On Ebay. It's one of the prototype snakes made for the game. The only one I have ever seen.
6 months later
#316 2 years ago
Has anyone taken their Rev 1 black shooter ramp and stripped the paint off it to make it a Rev 2 ramp? What did you use to seal or clear coat it? Is there a thinner layer or low friction paint
Are there any other differences between the ramps?
3 months later
#317 2 years ago
Just had an issue occurred last night with my DK power tap and 1 of the 2, 2amp fuses blowing. I've had the same mods installed on my Guns N Roses for over 2 years and it suddenly it caused the fuse to blow on the power tap. I have at least isolated which mod apparently is causing it to blow (my undercabinet LED strip lighting). My question is can I increase the fuse ratings to accomodate a higher amperage?
#318 2 years ago
Quoted from djh00000:
That looks awesome. How much was it?
2 months later
#319 1 year ago
Hi guys. New to pin side and thought I would share the mods my mate has done to my guns n roses pin in Australia.
7F4C745B-46EE-4291-A23E-16872E78FA04 (resized).png45A77C01-49E9-4894-AAD4-04031D125C0B (resized).png706558EF-6A35-4A96-AF2A-BCB938D1506B (resized).png6E93A2E9-702D-4189-8574-2AABCAF4E737 (resized).png99F9D6F3-B367-48A9-B518-97B9EE4AB985 (resized).pngBD0FECEA-C569-4401-B812-C4DA21AFA833 (resized).pngD46856C2-8416-437F-84EF-5250F1463F2E (resized).jpeg9E295AAA-A0B4-419E-A08B-41BBB8859489 (resized).jpeg6A6E20EB-03CA-4368-A3E6-B87938357653 (resized).jpeg23C4F1E3-F499-4D8A-9486-8D4E81CC7709 (resized).jpeg8124E79F-A393-4B11-BF5C-A524B7836F9C (resized).jpegAEBD06FC-CF7F-46B8-9DE8-7916776A10D7 (resized).jpeg
#320 1 year ago
Nice work. Thanks for sharing.
#321 1 year ago
Quoted from Dvs14:
I dig the grips!
1 month later
#322 1 year ago
Ok... while I don’t know if you would exactly call this a true “mod” I think it’s pretty damn cool. I found some “props” inspired by pic of Keith Richards plus added some extra McFarlane amps and guitars i picked up here and there.
6860D024-48C5-4566-B7A9-BF78E3AD272C (resized).jpegC7075DC8-9518-40DC-8F3E-4EA0B17B3250 (resized).jpeg7E6F0B21-B63F-4C09-8D67-3B0B6B74CB48 (resized).jpegD7240333-3F7E-4BFE-93E8-3B412C146C23 (resized).jpeg
#323 1 year ago
I think that looks really cool.
#324 1 year ago
killer, like the cabinets and amp head, you make those?
#325 1 year ago
Thanks guys ....
Quoted from ccbiggsoo7:
No, the 2 amps behind the G ramp come with the McFarlane Toys Slash figure but usually you get only one unless you buy the "deluxe" version. Mine came with 1, I picked the second one up loose. The one behind him with the booze and cigarettes is another McFarlane piece I also found loose so i don't know for sure which one it originated from but it fit nicely there IMO. The double neck guitar actually came from a Jimmy page figure. Slash plays the same model in concerts but it's black ..oh well! I thought it made a good prop and dresses up the light post.
#327 1 year ago
Quoted from HighwayStarr:
Thanks guys ....
I Love the bottle, the cans and the cigarettes! Where did you get them?
#328 1 year ago
Quoted from tneh:
Thanks- They are simply “doll house” parts via the Internet - I got the whiskey and smokes from different sellers in China but the Budweiser’s were from a domestic seller and cost almost as much as real beer! - lots of options out there - domestic sellers seem to have minimum orders but quicker turn around .
China parts were cheaper but took a few weeks to receive.
#330 1 year ago
Quoted from Nelly:
I upgraded the grips on the gun shooter. Added real Ruger rosewood grips. Also painted the mounting plate black so that only the gun was chrome.
[quoted image] [quoted image]
which gun grips fit this game?
#331 1 year ago
Ruger 22 revolver.
It requires a little bit of sanding, but is a darn close fit.
Here, take your pick.
http://www.riograndecustomgrips.com/rugernewvaquerogrips.html
We went with this one, which they still have in stock.
Arcade Upkeep
$ 12.50
Gweem's Mods
$ 17.95
$ 259.99
$ 99.00
Arcade Upkeep
