I just went in last night and installed the M&M Creations MRS switch for the snake pit bowl in the rear left of the game. I couldn’t remember how many ball revolutions i got in the bowl before with the mechanical switch, but from going to a magnetic reed switch now, i can get between 3 to 4 switch hits when it swirls around in the bowl.
The switch is customized based on the dimensions of the bowl. As can be seen in the picture, I put my MRS just to the left of where the original mechanical switch used to be. I only took out the 2 screws holding the snake pit bowl ramp in and was able to squeeze my hand in there to install the MRS.
After the installation, you might be able to get more hits in the bowl if you put it a bit more to the left, near the exit from the ramp that feeds into the bowl. However, it may more consistently register “5” hits with a full shooter rod pull versus where i have it where it could either be “3” or “4” hits. You may want to experiment and play around with what you like before applying it with the adhesive.
26FB76F2-6FE9-4FE5-B24B-9B66A5ECA153 (resized).jpeg2B01BC0C-0008-4105-9C3C-9B8E8256A917 (resized).jpeg
