(Topic ID: 57299)
DE GUNS N' ROSES CLUB - GNR - Members Only!
By MrBellMan
10 years ago
  • 2,526 posts
  • 274 Pinsiders participating
  • Latest reply 37 days ago by mozach
  • Topic is favorited by 88 Pinsiders
There are 2,526 posts in this topic. You are on page 35 of 51.
#1701 4 years ago
I found a dodgy repair on the snake while stripping the playfield so had to give it a quick lick of paint.
20200402_085604 (resized).jpg20200402_085604 (resized).jpg20200402_145050 (resized).jpg20200402_145050 (resized).jpg20200403_163357 (resized).jpg20200403_163357 (resized).jpg20200402_145059 (resized).jpg20200402_145059 (resized).jpg20200403_163324 (resized).jpg20200403_163324 (resized).jpg20200403_163403 (resized).jpg20200403_163403 (resized).jpg20200403_163618 (resized).jpg20200403_163618 (resized).jpg20200403_171856 (resized).jpg20200403_171856 (resized).jpg
#1702 4 years ago
Quoted from pa_cramer:
I found a dodgy repair on the snake while stripping the playfield so had to give it a quick lick of paint.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
I sanded and curved the head out which made it easier to repair. I've seen some photos of this done before and thought it looked better.
Added the fangs and 6V LED strip.
#1703 4 years ago
Quoted from wolfemaaan:
I turn the spotlights so they are not line of sight in my eyes. Looking at those will get annoying
Yeah I'm hearing ya. I have to build the playfield up first and then I'll reposition them.
Just wanted to figure out the location before doing it. I'll probably end up buying a new set of lights anyway. I have some less intense LEDs that will probably help. There'll be a lot more light through the playfield once I'm finished so they'll only be there for show really.
#1704 4 years ago
Quoted from Jrotten:
GNR completed[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Looking good.
Where did you get the duff decals from?
#1705 4 years ago
Can anyone tell me which is the correct leg type for this machine? Is it the smooth one or the one with the groove in it?
Thanks people!
4F2C0423-87AF-452D-822F-37690E401D0D (resized).jpeg4F2C0423-87AF-452D-822F-37690E401D0D (resized).jpeg
#1706 4 years ago
My GnR has a groove in the legs
#1707 4 years ago
Quoted from allsportdvd:
Thanks people![quoted image]
These are original legs. The ridge starts much further down the leg from the bolts than the one in your picture.
8AFCDAD3-6672-4030-8E01-034E9B2004A9 (resized).jpeg8AFCDAD3-6672-4030-8E01-034E9B2004A9 (resized).jpeg
#1708 4 years ago
Quoted from Boof-Ed:
These are original legs. The ridge starts much further down the leg from the bolts than the one in you’re picture.[quoted image]
Great - so neither the smooth legs or the Ridge I have on mine are correct lol
#1709 4 years ago
Yes the original legs start further down for the ridge ,that's what is on my also
#1710 4 years ago
My GnR legs are original: they're about 1" longer than B/W and the metal fold at the bottom, come to a point. B/W legs are rounded off.
#1711 4 years ago
Looking good.
You didn’t ask me but since there is no response yet I figure I’ll answer - a guy sells them on eBay - just search for “Guns N’ Roses pinball” and you will find them along with album cover stickers to replace the piano key drop targets . The DUFF targets are padded. I have a set but you really can’t see them. Honestly I’m prob the only person who’s ever noticed them in my machine
#1712 4 years ago
Need some help..
This may be the first problem I'm beyond my ability to fix with this game.
My kid was playing this morning for awhile just fine then came up and said the balls weren't coming into the shooter lane.
My 6 ball assembly lockout is not allowing balls to be sent to the shooter lane.
I have check all fuses and for corrosion on the holders. Wiring and connections on the PPB are solid. All other diagnostic tests besides that coil are testing fine. I can physically move the plunger on the assembly without any obstruction. The ball through switches are testing fine too.
Ohms on the coil are coming back at 10. Coils all look original throughout the game, or had been serviced quite a while ago. Stock 25-1240 is in the ball lock. Where else, and how, can I test or should be looking at?
Is it just time to start putting on new parts? I have a local guy, but not sure if they are presently doing house calls
15871299668024105374669736193960 (resized).jpg15871299668024105374669736193960 (resized).jpg
#1713 4 years ago
Start with testing the coils in diagnostic mode from coin door switches. The display will tell you which coil is firing. You can scroll through all the coils & see if they are firing. John
#1714 4 years ago
Did that.... all but the ball lock coil are firing. Looking over the manual, I'm trying to find where the Q46 transistor is on the CPU
I even checked and replaced the flashers (1R x2) on the back corners. Cant get then to flash either, so I think I'm on the right path...
Just hoping I missed something else, simpler
#1715 4 years ago
Just read your post again. So the only coil not firing is the one in question? If it's not firing then I'd change it out & make sure you install new coil sleeve also, clean assembly with 50/50 alcohol/water mix.
#1716 4 years ago
Correct... both coil lock out 1L and back panel flashers 1R are not properly cycling in the test mode. Since they are on the same circuit, I'm leaning the problem is upstream of each component.
I have the full manual with electrical schematics, but I'm getting lost as to where on the CPU board everything ends up, Q46 is where the manual says, I just cant find it. Plus at this point I'm beyond my skill level for how deep I want to get into electric repair if board soldering is needed. I'm still hoping for a wiring dummy fix or corrosion removal.
#1717 4 years ago
Gotcha, I don't get into board repair either. It's usually something simple rather than chasing a board transistor.
#1718 4 years ago
Always check your fuses first.
#1719 4 years ago
Quoted from MRG:Always check your fuses first.
That was the first thing I checked. Fuse continuity and inspection of the holders
#1720 4 years ago
Lower left of the CPU will have a horizontal row on transistors. They are labeled so finding which is Q46 should be easy.
Unfortunately, you are more than likely looking at a problem that with involve desoldering and resoldering, as Q46 probably went open
#1721 4 years ago
Screenshot_20200417-122832 (resized).pngScreenshot_20200417-122832 (resized).png
Disregard the circled transistor, I just reused a generic imagine to show the location of the transistors
#1722 4 years ago
After a few hours with a local hobbyist on the phone, we trouble shot everything we could... it finally tested after reseating all the plugs. Not sure if we fixed what wasnt broken or just gave it a lifeline on old parts.
Either way I learned a lot today, and appreciate the help from a local. Have good ideas if it acts up again as well. Back to more screaming at Michelle.
#1723 4 years ago
Quoted from Foraree34:
Glad to be of help..... Just remember to upgrade that PS.. .. Those originals are frustratingly awful.....
#1724 4 years ago
Quoted from Sonic:
XPin has been rock solid. Seem much better than Rottendog power supply.
#1725 4 years ago
Xpin ordered... looking forward to it
#1726 4 years ago
Quoted from MJW:
Absolutely agree....that darn Xpin cleared up problems I've had/seen in TFTC, GNR, SW, JP, Tommy...R&B.... just in my small circle of life.....
#1727 4 years ago
Re-posting as problem persists. Right flipper is moving in slow motion. Have tried replacing the flipper board from my Tommy (problem persisted) and also replaced power board with an extra one (problem persisted). Previously, all the flippers were really strong, actually too strong and had to change the flipper rubbers to stop flying balls. Any ideas on other things to check? I was told to try a PIN-LED flipper board as this may resolve the problem.
Thanks for your help!
#1728 4 years ago
Quoted from pinballjah:
Hey bud did u already change the flipper coils too your new ones you got
#1729 4 years ago
Quoted from HighwayStarr:
#1730 3 years ago
Quoted from Williampinball:
Yes, they are all the GnR replacement coils.
#1731 3 years ago
Settings question.
In free play is it possible to set the extra ball buy in?
I have it set on free play, buy in set to extra ball and limit at one, but it goes straight to match at end of ball 3. Either it’s not able to do this or I’m missing something. Checked the buy in button in switch test and it registers.
#1732 3 years ago
You can use buy in button at anytime during a game. Start a game, ball in shooter lane then press extra ball button. When game is over the display will tell you to buy in. Push extra ball button again & play the 4th ball. Good to go. John
#1733 3 years ago
Also, You can use buy in on ball 2 or 3 at anytime during the game, I don't use it unless I'm having a good game!
#1734 3 years ago
Thanks, will give it a go. Slightly different from WMS extra ball buy in
#1735 3 years ago
You don't have to program anything. Just leave it on free play.
#1736 3 years ago
Ok I had this happen too me years ago and I don't remember what it was now ,was it doing it before you changed the coils
#1737 3 years ago
I never replaced this coil, I only replaced the upper left. When I got the game, the problem flipper already had the upgraded coil installed. It was working fine for a couple months but has gone back to being very weak again.
Initially when I got the game, it had the same problem. What was happening was the auto plunger was causing the inside insert for the flipper button to become misaligned. So I increased the height of the mech by the flipper button on the inside to be further away and this seemed to fix the problem. There is no issue with misalignment anymore with the flipper button mech. I can attach some photos if that is helpful. Thanks.
#1738 3 years ago
My GNR is completed, looking for custom color instruction score card set for the Apron. Any Help?
#1739 3 years ago
Had these made ..
8F2D783F-5902-4667-ACBA-D1EC77C9D531 (resized).jpeg8F2D783F-5902-4667-ACBA-D1EC77C9D531 (resized).jpeg8F9CE660-4501-4C8D-86DB-93C58655C884 (resized).jpeg8F9CE660-4501-4C8D-86DB-93C58655C884 (resized).jpeg
#1740 3 years ago
Quoted from Sonic:
Out with the old...
In with the new! Plays just as it should!
20200422_221357 (resized).jpg20200422_221357 (resized).jpg20200422_225915 (resized).jpg20200422_225915 (resized).jpg
#1741 3 years ago
Quoted from Sonic:
What problem are you speaking of? Thanks.
#1742 3 years ago
For those seeking apron cards, check out pinballcards.com
Whats an Xpin board like that go for?
#1743 3 years ago
Out with the old...
In with the new! Plays just as it should![quoted image][quoted image]
Can you share the link and the model number of the boards you purchased? I thought I had previously looked for replacements (even though my boards work just fine) as a preemptive measure to maintain the machine working better for the long term.
#1744 3 years ago
I'm looking at selling my extra GNR translite signed by all band members except Axl. I have pictures with everyone of the members with the translite except Duff but have my picture with him after I had him sign both of my translites (I have one in my own machine which I did have Axl sign). Just wondering what going price would be as it's hard to put a number on it...
15876557926918681434290022762545 (resized).jpg15876557926918681434290022762545 (resized).jpg15876558215651506580283061842348 (resized).jpg15876558215651506580283061842348 (resized).jpg15876558705222023988395734103219 (resized).jpg15876558705222023988395734103219 (resized).jpg15876559090556940083557479973378 (resized).jpg15876559090556940083557479973378 (resized).jpg
-1
#1745 3 years ago
Quoted from DrMark12PA:
I’ll give you a $100.00 for it.
#1746 3 years ago
If u had axl sign it.. I would give u $500 for it .
Did Slash sign it? My bad saw the pic with Slash
#1747 3 years ago
this:
https://xpinpinball.com/product/xp-de5047/
#1748 3 years ago
stern legs are what most use for the data east games. heres my original next to metallica and lotr
84156971-23AA-4298-AA8B-2875772954A3 (resized).jpeg84156971-23AA-4298-AA8B-2875772954A3 (resized).jpegC473631F-B0C1-4D6C-9DB5-27DB17BD6A05 (resized).jpegC473631F-B0C1-4D6C-9DB5-27DB17BD6A05 (resized).jpeg
#1749 3 years ago
ignore this..... and that would be one of the first things you should check, coils very seldom go bad.
#1750 3 years ago
Quoted from MJW:
about 10x better actually!
$ 50.00
Duke Pinball
$ 18.95
7,200 (Firm)
Kingston, MA
6,300 (OBO)
Allentown, PA
$ 45.95
$ 49.00
$ 24.95
$ 549.00
Juz PINBALL Mods
$ 18.95
6,000
Franklin Square, NY
YouBentMyWookie
$ 39.00
Arcade Upkeep
$ 285.99
PinSound
$ 28.00
$ 25.99
Lee's Parts
8,999
Richfield, MI
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/guns-n-roses-gnr-members-only/page/35 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
