Hey folks - I'm stuck and would love any help you might have to offer.
My Guns N' Roses pin was working fine when I noticed one of the piano keys had broken. I swapped it out with my last available replacement and put the playfield back in the machine. Turned it on: everything seems fine, but it won't play.
Specifically, it doesn't try and eject the ball. I checked the trough and the balls for a while, mainly because the ball launcher was firing so I assumed it was just the ejector. However, when I went into diagnostics two things became apparent: nothing happens when "flashers" cycle*, and nothing happens when "cycling coils". I tried going coil by coil, and nothing. Using the flippers to go through the menus, the right flipper seems to work, but the left flipper barely moves.
I've visually inspected all the fuses, especially F5, and none look burned out. I'm not sure what I could have done with the simple operation I performed, but I'm stumped and devastated that I've temporarily killed my machine.
Thanks in advance.
*I'm assuming flashers are the large lamps behind the translight. All lights come on fine with the exception of the large lamps - those never come on through any diagnostics.
