Hi there,
I've been working on a Gulfstream for a while now but I haven't been able to get some things working yet.
They may be related so I'll tell you everything that is going on with it.
The two main issue that I can't figure out are the reset bank under the playfield doesn't reset and the flippers are reversed. It should reset the "special letters and the tic-tac-toe numbers but doesn't ever reset. The flipper wiring appears correct by looking at wire colors from buttons to coils.
The other issues, in case they are related, are no 5x scores registered, either 500 or 5000. The kickout holes don't kick out despite good switch contact. Finally, the numbers don't advance on the tic-tac-toe grid.
I feel like I've looked at most possible causes but I wanted to throw it out the to see if any of you wanted to take a crack at it. I have the manual and schematic in hand if you have any suggestions.
