Quoted from Skybug:Are you sure it wouldn't be too heavy on one side that it would pull the whole workbench down?
Yes , I tried pushing it over with it clamped and I felt the playfield flex/bend and not feel like it was going to flip over.
But for safety and piece of mind, loading it sideways it has a better center of gravity.
The feet on it are farther out for balance,at first i thought it would be top heavy too ,but after clamping and shaking it ,i was convinced. I would still hold the playfield with one hand while tightening screws to be safe.
Nah ^^,I am not that tall <6 feet.
The pop bumpers were at 59 & 63 inches (for me approximately shoulder height) not hard to do them. (no hunching over)
The good/better way to clamp it is sideways, but I would remove the outer shooter lane rail which is if you look on the back of the playfield is being held with small phillip wood screws (on the GS I believe its 4 screws) the reason i clamped it on end was for an easier and complete teardown I am doing. But do not recommend end clamping for beginners , plus it depends on what model you have or purchase as some clamp tables are of poor quality.
When loading sideways put good quality masking tape on the playfield edge at the clamping point that removes easy to protect the finish if you go past where the rail sets to protect from scratching the finish.
That would be best. ^^ In fact I would do it sideways myself next time,as it has a wider clamp grab area.
Quoted from Pafasa:Stand the playfield on its end with the front on the floor and clamp the side of the playfield into the end of the workbench clamp to steady it.
You could do that also^^^Good idea, its the safest of all Pafasa ^^^ better for Sky to handle it that way.
