Quoted from Duster72:Is there anything I can do about the rocket kickback going SDTM? I didn't see a ball save in the menu. Any other suggestions?
If all else fails, there is just enough play between the screws and kickback bracket mounts, that you can get about .25 degree trajectory change by loosening up the wood screws and re-orientate the kick assembly, and angle it more towards the flipper, then re-torque the screws. (Keep in mind this is not an adjustment, nor is it adjustable) It's just the play between the screws and bracket which has a tolerance margin that you can manipulate the orientation that will reduce sdtm.
