(Topic ID: 201799)
Guardians of the Galaxy owner's thread
By Blacksun
5 years ago
  • 7,891 posts
  • 665 Pinsiders participating
  • Latest reply 5 days ago by Duster72
  • Topic is favorited by 259 Pinsiders
14 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7,891 posts in this topic. You are on page 133 of 158.
#6601 7 months ago
Quoted from Oneangrymo:
quick question do you only get up to three haydon enforcers per game, or can u get more?
They cannot stack higher than 3, but you can get them back up to 3 as many times as you can hit the 5 yellow hadron targets on the playfield.
#6602 7 months ago
Few left: orb protectors
Mod - For Sale
New - “New & improved version. Made from 1/8” Pet-g plastic! (13th run just made…) GOTG Orb Airball protector - combines a few things: 1. Upfront Orb - airball protector 2. Ba...”
2022-08-18
Saukville, WI
20
Archived after: 67 days
Viewed: 1573 times
Status: Not sold
#6603 7 months ago
Quoted from mcvetyty:
The maximum number of Hadron Enforcers can be changed in the settings.
#6604 7 months ago
I think the Haydron setting in the game specific menu.
#6605 7 months ago
I had a great game this am before work while having my coffee
its actually pretty fun
So does the game like end end after the final wizard mode like Jurassic park does?
#6606 7 months ago
Quoted from Markharris2000:
Do you have a stock SD card available to install ? Does the playfield light up? Any LED on the CPU board in the back box lit up?
I will have to report back. Game is at my parents house and I have the back glass key at my house.
#6607 7 months ago
Quoted from jsm172:
Just a tip: hang the backbox key inside the coindoor on the hook made for that key. So easy for that key to get lost otherwise, and a huge hassle if you loose the key.
#6608 7 months ago
Nope. And thank goodness. The most valuable feature in the game is Quill's Quest 2, a hurry up worth 10% of your score and can get up to 240% with the right conditions. (120% is the realistic max, though.) You can achieve this (a second time) after getting through the wizard modes.
#6609 7 months ago
It doesn’t end. It just starts over and keeps going
#6610 6 months ago
I ended up doing a bit of plastic surgery today. My original plan was just to swap out a warm white spot next to Groot’s face. As I started taking things apart, I realized there was a break in the plastic behind the orb lock. I glued it up with plastic specific super glue and added a couple snips off a small zip tie to reinforce that very thin section. I’m a little surprised it was designed that way.
1E7085EB-1BA2-42A2-BE1C-3B4F5A0EB97B (resized).jpeg9ED15F61-CF55-4DED-8348-77372CE1EB75 (resized).jpegimage (resized).jpg
I also found that there were mismatched spacers on the upper layer of plastics. Not sure if that is normal, but it seems like the shorter spacer with a long screw feeding into the hex stand off under the spot light might have put some extra torque on the thin plastic causing it to snap. Just to be safe, I 3D printed a couple of new spacers that are the same length before putting it all back together.7E7A1A38-BE2F-4F68-B219-41606BC11B7D (resized).jpeg362A9030-DC49-4D42-B9CC-EC1DBE657AA9 (resized).jpeg774B47DF-FC73-4997-BE7C-ABB8EF132FD6 (resized).jpeg
This is my story about how changing 1 bulb turned into a 2 hour job.
#6611 6 months ago
Quoted from bigguybbr:
I also found that there were mismatched spacers on the upper layer of plastics. Not sure if that is normal, but it seems like the shorter spacer with a long screw feeding into the hex stand off under the spot light might have put some extra torque on the thin plastic causing it to snap. Just to be safe, I 3D printed a couple of new spacers that are the same length before putting it all back together.[quoted image][quoted image][quoted image]
Exactly 1 of the 2 reasons I sell the orb protector. It helps with airballs in the front AND protects that thin plastic by Groot. Many have had this break during game play.
Those that buy after the break will glue down to my protector fyi
Mod - For Sale
2022-08-18
Saukville, WI
20
Viewed: 1573 times
Status: Not sold
#6612 6 months ago
Quoted from cpr9999:
cpr9999
Ad link works but unable to purchase, you may want to check your market / settings / inventory level on the item?
#6613 6 months ago
Quoted from PinballHaven:
cpr9999
No settings - this is a straight up Pinside Ad and people message me to buy.
#6614 6 months ago
Oh I thought you had a shop set up my mistake.
#6615 6 months ago
Hey, does anyone have endless booting on this game?
I flash a memory card (not a "stern" one) and it will work for about 20-30 games and then just go into an endless loop upon bootup :/ Grrrrr. Keep losing my scores...
It is 1.09 for the record, cause it's the Cleland which I think is his latest version... has this happened to anyone else?
#6616 6 months ago
Quoted from Lobo2k:
Check the voltage output from the power supply (you have to take the metal cover off by the service outlet). It sounds like it may be dropping below 48v, which would cause what you're seeing.
#6617 6 months ago
Quoted from PinMonk:
The place where I put my pinmonk fan?
Those are amazing btw I have them in all my recent Stern's (and my Rick and Morty which was essential!).
I should also mention, I just put in a new memory card and it seems to work. I been swapping 1.10 and 1.09 (Cleland mix). It's only the Cleland mix, on a "non-stern" (but more expensive) memory card that this is happening on from what I can tell.
I should play the 1.10 more though and see if it happens at some point on it..
#6618 6 months ago
Quoted from Lobo2k:
Yes, the step where you take off the metal plate at the bottom of the power supply to get it out exposes the bottom of the power supply where the leads connect to the power distribution board to the left. The +V leads should be outputting at LEAST 48v (maybe a little more). If they're below, turn the little pot on the side of the terminal block until you get like 48.2v so you have a smidge of overhead in case it drops a bit under load.
#6619 6 months ago
The way I've been solving it though is to load new code. Does that make sense?
Thanks for the help...
#6620 6 months ago
Quoted from Lobo2k:
Yeah, I don't understand how that's connected, unless the SD card or SD card slot is the root problem after all. Where did you get your non-Stern cards? If they're Sandisk and you got them online, they could be unreliable fakes. I only buy them at B&M stores for that reason.
If the power supply is low on voltage output, it will always eventually reboot the game.
#6621 6 months ago
My pro froze so I shut it off now it’s dead, mode board light are on, speaker lights on. But monitor is dead and nothing on the playfield.
#6622 6 months ago
Quoted from Sluggo39:
The Stern SD cards are garbage and are often the root cause of these issues. Buy a new Sandisk 16 or 32gb SD card at Best Buy or Target (not online, B&M only if possible) and image the code onto it using Stern's image here and tool instructions:
https://sternpinball.com/support/sd-cards/
#6623 6 months ago
The Stern SD cards are garbage and are often the root cause of these issues. Buy a new Sandisk 16 or 32gb SD card at Best Buy or Target (not online, B&M) and image the code onto it using Stern's image here and tool instructions:
I believe it’s an aftermarket card because the game is running Clelands code. So basically set back to original code? Thanks for the help.
#6624 6 months ago
Definitely sounds like the card it not initializing the system. It’s possible it’s not inserted all the way, so check that first. But also possible it’s just a bad card. So best to get a fresh 16GB Sandisk card from Amazon and write the factory sdcard image to it. Then firmly insert the new card with factory code. Let us know if this allows the machine to boot.
#6625 6 months ago
Easy enough to make a new card (I recommend only B&M stores, not Amazon, not Ebay - too many Sandisk fakes, even in "sold by Amazon" sales. Worst case if you don't have B&M close, try B&H or Adorama) and just pop out the one you have now and put the new one in after you image it with the code to see if that fixes it for you.
#6626 6 months ago
I’ve decided to put the spinner on the left side of my pro. Been debating about it till I read we’re some had installed it on there’s n liked it. Pinball life has everything I need so we will see.
#6627 6 months ago
Are Pros supposed to go on the line in Sept?
#6628 6 months ago
Quoted from big-c66:
Spinner? How...
#6629 6 months ago
Ya, I don't get it man. No, it's from Best Buy... and an expensive card at that. Can't remember the brand but it's definitely a higher quality card than what Stern has been using. I wonder if it's something with 1.09. Well anyways.....I actually had a "stern card" from another system ... I flashed it with Cleland last night and I will keep an eye on it. I'll definitely check the power like you suggested..... but like I said, the "fix" is literally I just put a new memory card in and it works again. It wouldn't boot with my card, and I put the new 1.09 in and it worked fine. Both were Cleland 1.09s.... anyways, we shall see. Thanks
Also I promote the shit out of the fans you sell! They are awesome. It's the first thing I do when I get a new Stern now lol
#6630 6 months ago
Take pictures when you do it! I purchased the spinner from PBL eons ago to do this very mod, but have been hesitant to make the required non-reversible changes to the stock playfield. I think I can get over the wiring part (must tie into the existing rollover instead of the much more elegant spinner matrix SW found in the premium), but the additional hole you must drill in the playfield, and the notch you must cut in the plastics have PAUSED my enthusiasm.... but I would like to see it being done to give me the confidence to jump back in to the MOD.
#6631 6 months ago
Quoted from Lobo2k:
Maybe the new card was too high capacity for the Spike2? I'm not sure what the upper limit it can read are, but probably 32GB or 64GB is the top.
Quoted from Lobo2k:
Thanks! You're not alone. I've noticed that once people try one they come back and get another quiet fan kit first thing with every new pin they get. I don't blame them, that power supply noise drives me insane out of the box.
#6632 6 months ago
Quoted from gliebig:
I believe they are as soon as Led Zepplin is done. They are probably running Bond on the main line and the games that are getting phased out, LZ, GOTG, TMNT, on the secondary line.
#6633 6 months ago
Pros go online this month (if they aren’t already) I have my 2nd one preordered (traded my original for a Star Trek pro a couple years back)
My wife has been unhappy with me trading her guardians hence the 2nd one. My old one was proudly running the Clealand code, and I’m thrilled it’s been updated. I’m pretty certain the machine will ship with 1.10, but clealand is I think running on 1.9? Will I be able to go backward? That code for me anyway is a make or break for this pin
Thanks as always!
#6634 6 months ago
Quoted from cldgin2:
GOTG is the one pin my wife tells me I’m never allowed to trade or sell.
#6635 6 months ago
My wife loves ours too. I have had a few goes at trying to sell it.
#6636 6 months ago
Nope! Tried on a Stern card, and issues. F*!!!
I'm gonna try to check the power like you suggested, I just don't know why it would work for a few days and then stop. Literally, what happens is:
1) I flash a card, it works
2) Play 30 or so games
3) Turn it on after 3-4 days and it's stuck on an infinite loop
4) Reflash same card
5) Repeat steps 1-3.
Annoying.
I would keep doing it forever if I had to, takes 5 minutes to flash a card....but really sucks losing my scores. Arg
Right now I'm testing with STERN code (1.10 vs Cleland 1.09)....... I want to see if this pattern repeats. So far, it hasn't. But I'm only on day 2 and it usually takes a few days.
#6637 6 months ago
Quoted from Lobo2k:
Annoying.
If not the power, then maybe dust or a bent pin in the SD card slot? If the pin is only slightly bent, I can see it losing connection from vibration/whatever. Same thing if a dust blob got in there.
#6638 6 months ago
Thanks as always!
Yes you can swap the 1.10 factory code with cleland 1.09 and back.
#6639 6 months ago
Quoted from Lobo2k:
Annoying.
Have you tried it with the write protect tab on the card enabled, just curious if something is somehow corrupting it while it's turned off? I'm really not familiar with Spike games but if they have a button-cell battery for time backup perhaps it's low on voltage and corrupting it while turned off?
#6640 6 months ago
That’s good news! However I may wait until some one braver than I confirms it lol.
#6641 6 months ago
Stern needs to make more toppers with the last run!!
#6642 6 months ago
I put spinners on both sides of my GOTG pro and tied them both to the same hadron 2nd from the left. It somewhat nerfs the game because it spots you that hadron on every orbit. This makes Sanctuary a lot easier but the cool factor of having spinners is what I like. Couple words of advice is follow the thread I put in below it is very helpful and well documented. Measure twice and cut once on your plastics! Pretty easy mod to do.
https://pinside.com/pinball/forum/topic/spinners-for-gotg-pro
#6643 6 months ago
Quoted from aaron6920:
Trace the plastic out on cardboard, then cut the cardboard. After you like how the cardboard fits and looks tape it to your plastic and cut exactly what you need.
#6644 6 months ago
Quoted from Spiderpin:
Freaking smart words here
#6645 6 months ago
New SD card and reimage did the trick, now to get another card and put clelands code back in. Thanks Pinmonk and MarkHarris for the help greatly appreciated.
#6646 6 months ago
I have done it in my game.
#6647 6 months ago
What’s the going price for a nice pro with a good bit of mods? I got mine listed at $6,800 obo with no luck. I was going by previous sales but not sure
#6648 6 months ago
Quoted from jsm172:
I imagine it's hard right now with stern remaking them. Probably the worst time to sell one aside from a market crash or something
#6649 6 months ago
Guess I’ll lower some more and if no bites I’ll just hang on to it. I was able to sell my topper for a crazy amount so that helped
#6650 6 months ago
Quoted from jsm172:
NIB pro listed right now in the markt for $6899. Unfortunately mods add nothing to the value of a pin these days...
10,000 (OBO)
$ 29.99
PR Mods
Sound/Speakers
$ 49.99
Toppers
7,200
Cincinnati, OH
Precision Pinball prod.
Flipper parts
This page was printed from https://pinside.com/pinball/forum/topic/guardians-of-the-galaxy-owners-thread/page/133 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
