Quoted from nagamitsu:I can't confirm, and only going by their example pics, but one shows with having the capacitors soldered (more expensive one) other without, so you'd have to find/buy the correct capacitors or remove from existing motor and solder same way to new motor
Tim
As long as the motor part number is the same, just move the wires and capacitors from the old motor to the new one. I helped a friend replace the motor on a PoTC spinning disk, which had a motor, a connector and a capacitor. The 'official' replacement for the spinning disk assembly was $150, but as it turns out the motor itself is the same as most shaker motors, so I found the same raw motor part number for $39 and just moved the wires and capacitor. Job done. Saved $100!
