(Topic ID: 201799)
Guardians of the Galaxy owner's thread
By Blacksun
5 years ago
  • 7,891 posts
  • 665 Pinsiders participating
  • Latest reply 8 days ago by Duster72
  • Topic is favorited by 257 Pinsiders
14 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7,891 posts in this topic. You are on page 108 of 158.
#5351 1 year ago
Quoted from red-line:
Anybody have thoughts on ULEK vs laserrific plastic protectors? Early in this thread, someone mentioned that ULEK is acrylic and laserrific is something softer, so the ULEK would break easier. Not sure if anyone else can speak to that, or to the aesthetics of each.
Another question, as I'm about to buy a NIB pro - what do you guys pay for NIB? MSRP?
I have Ulekstore on every one of my games. First thing I buy. Great products and look great too. Buy with confidence!
#5352 1 year ago
I paid $5800 NIB delivered to my door with no tax.
#5353 1 year ago
Quoted from Tiltbob:
I’ve seen $5899 and I’ve seen $5999 lately. Or you could buy a like new one with some cool mods for $5300 from me I bought it nib from Trent at Tilt
Looks like you have a really nice machine! that drive is a deal breaker for me, though. Cheers!
#5354 1 year ago
Thanks! It would be for me too
#5355 1 year ago
Quoted from BroMan90:
I paid a bit less than that but from what I understand the discounts are becoming much less now. I was told it would probably be the last time I see a discount like that. If you call around you should be able to get 100 less than msrp shipped.
#5356 1 year ago
I think it might be time to move on from my Prem, but I love this game. Just needed to start Groot again to light Immolation for the second time in the same game!!
#5357 1 year ago
Has anyone else had the issue where Groot is not recognizing the 3rd ball to start multiball? The first 2 balls register no problem but when its time to lock the 3rd it doesn't recognize its in its mouth. Eventually it kicks out the balls after some time but I have to hit another ball in again to start multiball.
#5358 1 year ago
Quoted from JayTeeF:
Is this the 1st Groot MB or 2nd.
1st one is a three ball MB, 2nd is a 4 ball MB. if you already ready know that my bad. It had not happened to me. But I've only had my game for a month.
#5359 1 year ago
Quoted from Spiderpin:
This is the first Groot MB after hitting 3 balls in.
#5360 1 year ago
Could be a bad opto. Check on page 15 or run a switch test.
Switch #44 Groot Trough 3
9 - CN13 5 PNK ORG 10 BLK GRY Playfield Opto 9-SW-3 520-7064-00 rx
#5361 1 year ago
Thanks Spider. Will run through those tests and see what I can find.
#5362 1 year ago
This feels like a ridiculous question after having this game for months and playing hundreds of games but...
What exactly triggers Groot's mouth to open? Are there certain states of the game when it can't be triggered?
For the past few days it has been rarely opening. I having been testing switches to try and see if there is a problem and then I started thinking maybe I just don't actually know.
#5363 1 year ago
With default settings, 1 shot opens the mouth for ball lock of second ball. 3rd shot opens mouth again for ball lock of fourth ball. Fifth shot opens mouth for start multiball on 6th shot. In multiball it's closed until you hit it once. Then it opens to store a ball for 30 seconds of double scoring. Hit again to open mouth to store a second ball for triple scoring. Once you sink enough jackpots it opens and closes every few seconds for super duper jackpot needed for save zandar. It's used a lot actually. The wizard modes also use it.
Some modes you can't open it like Quill while 2 ball multiball is in play or when in orb multiball. Most modes allow you to progress towards groot multi though.
If you have changed the difficulty of groot to easy it's like 4 shots to the closed mouth to open it then it stays open to lock 3 balls for multiball. Doesn't seem much easier to me though.
As far as the physical trigger it's the opto right in front of the mouth.
#5364 1 year ago
Good thing I asked, I didn't realize there was an opto right in front of the mouth. I always went into the pops once or twice and then the mouth opened. Hitting groot in the mouth, a closed mouth, has never done anything.
What do you think that is? I am not very experienced in these things. Could the opto be broken from the factory or maybe just misaligned so the pops shakes into tripping? I just did a switch test of the opto and its not working but I can still get the mouth to open occasionally with a lot of bounces in the pops.
#5365 1 year ago
Quoted from cpm_:
It could certainly be misaligned or you could have a broken wire, also possible it wasn't wired up correctly at the factory if you bought it new and it's never worked. Start by taking the balls out of the game, lifting the playfield and tracing the wires for both optos back. The manual probably doesn't specifiy it so maybe post your pictures and have other owners verify the wiring.
#5366 1 year ago
I'd also send an email to stern support. If it's new it's good to start a dialog with them when you notice the problem. They just sent me parts for mine even though I'm out of warranty.
#5367 1 year ago
Quoted from cpm_:
One of the optos is broken, very thin solder wires there and it can break in a way where it’s still in about the correct spot but doesn’t make contact until the pops vibrate it and then it triggers his mouth open. Happened to me, yours is probably the opto chip on the right since the pops are close enough to vibrate it. Pinball life sells both sides optos about $15 for one and $17 for the other I think, I got a couple of both jic. The right one is easy to get to from above you can pop out one screw and loosen the other and rotate the plastic out of the way then you can get to the opto screws and pull the chip out, wire harness is easy to access from under the pf. Until the parts come in it’s a good time for ppl to practice getting to Cherry Bomb mb at least that’s shag I told ppl in my tavern(;
#5368 1 year ago
Thanks for the advice. I was playing around with it today and it definitely seems like the right opto. My temporary hack is that I left the screws a little loose and now every time the ball hits the left pop groot's mouth opens. I'll try to not get too used to super-easy mode while I'm waiting for a replacement.
#5369 1 year ago
I had a wire come of within 10 plays after unboxing of the opto present at Rocket. Apparently the soldering skills can be improved at stern …
#5370 1 year ago
Plan to finally install cpr9999 orb plastic protector and wondering if I still need the metal piece from stern as I put it back together.
I feel like this metal piece was pretty useless as my original orb plastic cracked anyway.
#5371 1 year ago
Quoted from Vino:
Nope, you do not need metal bracket from Stern.
#5372 1 year ago
Quoted from cpr9999:
Ty sir!
#5373 1 year ago
I still need to install mine (months later)
Are there any instructions or just remove what's there and reverse?
Haven't looked and not sure what's there on an le (with the movable orb parts)
#5374 1 year ago
Quoted from Vino:
The metal protector part was added to later builds of the PRO, after serial #275330. See Service Bulletin #191:
https://sternpinball.com/wp-content/uploads/2018/08/Stern-SB191.pdf
#5375 1 year ago
My metal protector unfortunately failed on my GOTG that is for sale the plastic protector is definitely needed with the metal crutch
#5376 1 year ago
Quoted from Markharris2000:
Thx, appears mine is a later build with the metal bracket but unfortunately did not help protect as bulletin indicates. cpr9999 protector installed now and ready to go - hope it will do the trick this time.
#5377 1 year ago
Quoted from Meegis:
Take a look at my Ad pictures. But pretty much what you said remove, add protector and reinstall.
#5378 1 year ago
Quoted from Babarr3445:
So I made the change to Cleland mod and noticed a different setting on Groot. I now have to hit the mouth lock three times and then it will open. I then hit the ball in three times to start multiball. I used to hit the mouth lock once, then it would open, and I would hit it in. I would repeat this three times to start multi ball. I know that this is a setting that can be adjusted. Can someone guide me?
Did you ever get the three times to start multiball resolved or find the setting??
#5379 1 year ago
Quoted from austinjw1955:
I believe it's the groot difficulty setting. Standard is hit, lock, hit, lock, hit, multiball. Easy is hit, hit, hit, lock, lock, lock, multiball I think. Not sure it's actually easier. The really easy setting seems to be hit, lock, multiball.
#5380 1 year ago
Finally got my GotG side armor rails in. They look sweet, but now I'm a little boggled. 3 of the 4 original screw holes lined up no problem and it's not going anywhere, but there are 4 new screw hole spots in the armor that would require drilling new holes into the cabinet. Like, umm, I bought the armor to protect it, not drill into the cabinet a few more times.
Now I'm torn if I want to fill in the holes with screws or leave as is.
#5381 1 year ago
What will it hurt?
#5382 1 year ago
Quoted from Hayfarmer:
What will it hurt?
The future of rock and roll!
#5383 1 year ago
Quoted from Rengozu:
Then don't put them in, I didn't on my JP armor and its fine.
You could use a little bit of double stick tape if you are worried about it being loose at the bottom but its pretty rigid.
Where did you find the armor?
#5384 1 year ago
Quoted from J-Freeze:
Pu-parts still had the Gold and Black armor variants available.
#5385 1 year ago
I hate asking such a simple question but can you adjust the shaker motor strength on guardians pro? I added one but it is really soft! Couldnt find anything on here, the web or the manual.
#5386 1 year ago
Quoted from Nelsonford218:
Yes, there is a setting for the shaker, with three levels. Can't remember what number, but you'll see it if you scroll through...
#5387 1 year ago
I went through it multiple times! Is it possible it's not on the pro since it didnt come with a shaker from the factory?
#5388 1 year ago
It’s Feature Adjustment #61 on my Pro.
#5389 1 year ago
Quoted from C-Note:
I do have that, but that is just how often it shakes, not the intensity
#5390 1 year ago
Go into game specific features - I think it’s towards the end so you can go backwards…
#5391 1 year ago
You can adjust it but its not in any settings menu.
You have to take the cover off the shaker and adjust the weights.
In relation to eachother-
Parallel = most intense
90° = medium
180° = least intense.
#5392 1 year ago
90° = medium
Dang, that's how mine are, guess it's just not very strong! Only other one I ever had was on my LAH, it was so strong it about rattled the game apart!
#5393 1 year ago
The shaker I put in my guardians shook constantly and violently. I didn't like it even on minimal settings and adjusted weights. I moved it to a different machine.
#5394 1 year ago
Has anyone started seeing NIB GOTG machines arriving from Stern factory? I have one on order and was told to expect likely delivery of "July". Has anyone seen a recent build GOTG machine arriving recently?
#5395 1 year ago
Sweet that they are still making them.
#5396 1 year ago
Two guys in my league here both got one quite a while ago already. I thought the new run was already done?
#5397 1 year ago
Quoted from bailorgana:
Just checked with my distributor... July run is still scheduled. I guess some NIB machines will flow in a few weeks.
#5398 1 year ago
I bought a NIB Guardians eight months ago. about six months in, after roughly 2500 plays (my wife loves this game!) started having issues with the Groot mouth. It would try to open and make it part way but not fully open, then repeat. Initially thought it was just switches being bent, but after some troubleshooting it was the motor itself that had failed somehow. It would 'slip' and not make the journey from one switch to the other.
Luckily I was still under warranty from Nitro Pinball, and they ordered a new motor from Stern and even sent a tech to install. The odd thing is that the motor worked fine for over 2000 games, but 2000-3000 games is way to early for a motor to be failing, don't you think?
My wife and I both really like this game. Get the Cleland sound mod if you can, and cool that Stern is doing another run so a bunch more people can own this awesome pin!
#5399 1 year ago
Hi fellow Guardians, I finally put the lit Orb Drop Target mod into its own thread so anyone can access the instructions whenever, enjoy!
https://pinside.com/pinball/forum/topic/guardians-orb-drop-target-mod#post-6352469
Screen Shot 2021-06-25 at 1.58.23 PM (resized).pngScreen Shot 2021-06-25 at 1.58.44 PM (resized).pngScreen Shot 2021-06-25 at 1.59.15 PM (resized).png
#5400 1 year ago
Quoted from Jonathan007:
Mine was doing the same thing. Stern sent me a new motor to fix it as well and I had about 2k games on mine. Got it in late November. Pretty sure it's the gearbox that went. Stern support has been great.
$ 125.00
G-Money Mods
Toys/Add-ons
$ 6.00
Apron Envy
Protection
$ 150.00
PinWoofer
Sound/Speakers
$ 130.00
Dijohn
Decorations
$ 299.95
Pin Stadium Pinball Mods
Led
This page was printed from https://pinside.com/pinball/forum/topic/guardians-of-the-galaxy-owners-thread/page/108 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
