I want to buy a GOTG Prem/LE. Someone let me help them help myself.
Quoted from pinnyheadhead:Balls can weirdly become magnetized. Who knows?
Checked earlier and none of the balls have become magnetised, so that's good!
Quoted from pinballaddicted:There is a metal tab on the eject side (left) of the shooter. If you bend it a little, so the ball bounces of the tab and in to the lane, the ball will stop bouncing straight back in to the shooter trough. This is common on new Sterns. What happens, the first ball is ejected in to the shooter lane, and the next ball takes its place. The first ball bounces back in to the shooter so now there are two balls there on top of each other and no ball in the shooter lane. Machine ejects two balls out. B/Ws had the same issue.
Good luck!
It happened to me yesterday and there was definitely a first eject with no ball appearing and then a second eject sent two balls into the shooter lane, so it sounds like it might be this, but I can't figure out which 'tab' you mean, or which direction to bend it - don't suppose you've got a photo?
Quoted from cyberkryten:Checked earlier and none of the balls have become magnetised, so that's good!
See the tab right in the middle of the photo. You need to bend that tab back towards the plunger. The ball will bounce off it and land in the shooter lane no back in the ball trough.
Good luck!
After playing Guardians a bajillion times and never breaking a billion. Yesterday in a competition I put 1.6 billion..... on ball one! Finished with 1.8. The latest code makes this game so much better!
Quoted from LOTR_breath:The latest code makes this game so much better!
Keep spreading the word. The people must know! My opinion, the code transformation is a modern marvel. I’m hard pressed to believe a game has been rescued as much as this one.
a question...
I'm thinking of selling my pro x-men to buy a guardians of the pro galaxy.
Do you think it's a good change? regards
Quoted from ATLpb:Keep spreading the word. The people must know! My opinion, the code transformation is a modern marvel. I’m hard pressed to believe a game has been rescued as much as this one.
Yep. I was a hater. Code is 100 times better.
Quoted from mannymasy:a question...
Yes. Big upgrade IMO.
Orb airball protector. Helps protect the spot that typically breaks - thin part near orb - back left side. Also protects front near pop up. Get rid of stern metal bracket!
https://pinside.com/pinball/forum/topic/gotg-orb-airball-protector-plastic-protector-in-one
Quoted from TomGWI:Yep. I was a hater. Code is 100 times better.
There is a tab on the top 100 ranking that you can generate a custom ranking, select stern, pinballs on the last decade and only the reviews on the past 6 months. That is a way to see the ranking after the code is more polished and almost finished.
Batman and GOTG are the ones that jump from the botton of the list to the top.
A friend has a Batman and never enjoyed playing, after the new code is one of my favorites.
I only played GOTG pro with the new code and loved it, not sure if the premium is ever better
