(Topic ID: 226888)
Guardians of the Galaxy Drop Target Problem
By Kholmes
5 years ago
  • 87 posts
  • 26 Pinsiders participating
  • Latest reply 9 months ago by Mr_Dinoman
  • Topic is favorited by 16 Pinsiders
There are 87 posts in this topic. You are on page 1 of 2.
#1 5 years ago
Hello all, I just received a Guardians of the Galaxy Pro edition delivered today. NIB. Set it up, and we began to play. As soon as the pinball hit the Orb drop target, it dropped as it should, then when I shot the ball in the Orb, the drop target raised as it should, and kept the ball. It failed to release the ball nor shoot another ball in the shooter lane.
Then all the relays started to click as if it were looking for a ball. It timed out sometimes, and then the trough would kick out two balls thinking it was missing one. The game worked properly until you hit the Orb.
I contacted Stern and they referred me to the dealer I purchased from. Stern walked me through the drop target check and it worked. They said they're have been some problems with this particular drop target. My machine was manufactured three weeks ago. I asked why would they send out a product if they're aware of this problem? Anyway, they said call the dealer and have them order me a new drop target assembly so I can I stall it.
I then attempted to troubleshoot with the dealer. They were helpful but still nothing. I physically looked at it, nothing looked out of the ordinary. The drop target worked, obviously has power, but may be a board issue?
Any thoughts or assistance would be greatly appreciated. Thanks!
#2 5 years ago
Ours on location has been having tons of drop target glitches too
#3 5 years ago
It's a VERY common issue with GOTG. When I bought mine; the rep warned me ahead of time of all the common problems with this particular machine. He said the drop target getting stuck was, by far, the most prevalent issue. He ordered me a new one (free for me) and told me to disable the drop target in the settings until the new one came.
I disabled it in the settings; but it still ended up getting triggered during Groot multiball and messed up the rhythm of the game.
Once the new drop target assembly came; I installed it, adjusted it for height and haven't had an issue since. Hope your rep helps you out.
#4 5 years ago
Belcaw, my rep said he'd order a new assembly, but as for the adjusted height, how did you do that? The rep also seems to think it may be a board issue. Thanks
#5 5 years ago
No should be an adjustment, Waxx knows the fix
#7 5 years ago
Thanks ovfdfireman
#8 5 years ago
Hey knolmes, I’m on my phone so it will be hard to type out but it’s basically one of a couple things that are the same problem. The drop target is not being knocked off the ledge but can be fixed easiest with adjusting the arm that knocks it off. I’m getting to a computer, give me a couple minutes.
#9 5 years ago
Thanks @Waxx
#10 5 years ago
Ok, it's similar to Star Trek and I did many different things on mine testing what worked for me. Basically you need to get the arm that pushes the drop target off the ledge closer to the drop and give the magnet more strength to do it. I disassembled mine entirely and adjusted the arm as well as some other tricks but the easiest solution that accomplishes the same goal I've seen is MapleSyrups:
https://pinside.com/pinball/forum/topic/guardians-of-the-galaxy-owners-thread/page/56#post-4562772
He just moves the whole bracket down which moves the arm closer by association, smart and easy.
Edit: I just read the above posts and while this is a common issue it does most definitely not require a new assembly. The assembly just needs to be adjusted correctly. Since doing that mine works 100% and is completely fixed. You could end up doing this at least once if you own a ST as well, just kind of goes with the mech I guess. (even though it is a redesigned mech from ST)
-1
#11 5 years ago
Thanks Waxx I'll give it a shot. I'll try maple syrup method and see how I can ever so slightly bend that bracket downward!
-1
#12 5 years ago
I called and the stern tech had me take the entire mechanism off the playfield and bend the sides in to get rid of the slop. It worked great.
#13 5 years ago
Cdonnerusmc do you have pics of what you did? Thanks
#14 5 years ago
I dont , but I can go down and pull it off and get pictures for you this morning. The game is extremely annoying when it wont release your ball. Haha
Quoted from Kholmes:
#15 5 years ago
Guys, I still need help with this issue. Stern is blowing me off. MapleSyrup and @Tungsten78. I sent both of you private messages.
Thank you
#17 5 years ago
My friend has the Pro version and having the same problem (got his like 2 weeks ago, probably made in the same batch). I called Stern yesterday on his behalf and they just offered to send me some new part. I forget what he called it, but it sounded like it was a newly designed part, as opposed to just a replacement part, but I could have misunderstood and maybe there was just a bad part that was put on the machine originally.
As a side note, my friend mentioned was that when the playfield is up in the air for maintenance, the drop target works flawlessly when manually activated.
I'll try to do some proper documentation here once the part gets here (unless someone beats me to it).
#18 5 years ago
@x-rug-x
I spoke to Stern today and they're sending me the entire drop target assembly. They said they're aware of this problem and claimed they've consistently told manufacturing over and over to fix this. Mine was made last month according to the dated stamp. Let me know if you get it and how it worked out please. I won't get mine until prob Fri. Thanks
#19 5 years ago
Shorten up the small spring.
#20 5 years ago
Quoted from Trekkie1978:
Tried that, didn't have an effect.
#21 5 years ago
Quoted from x-rug-x:
Did you make it really tight?
#22 5 years ago
It really is the distance of the metal plate and arm that push the drop target off the little plastic ledge. If you bend the plate so it is closer to the drop and closer to the coil it fixes the problem. It’s a poor design but I haven’t seen any attempt from Stern to fix the design.
It requires them to adjust it properly at the factory and cannot be tested by manually touching the target (which I’m positive is all they do at the factory).
#23 5 years ago
Can someone please post close up pics of what they did??? I really don't want to return this but another pinsider and I received ours this week and have the same problem you all have. We can't figure it out.....pics are a thousand words. A video would be even better. I have a 7 yr old son who is upset, as I am, and it's now collecting dust. Thanks guys
#24 5 years ago
Ok, using my phone at work here but the two red arrows are pointing at the design flaw. Magnet doesn’t pull up bracket up enough to push arm forward.
Edit: it’s why bending the whole assembly moves the magnet closer to the metal bracket the red arrow points at.
FE2976A7-9E4D-4321-A44F-996E988808CC (resized).jpegFE2976A7-9E4D-4321-A44F-996E988808CC (resized).jpeg
#25 5 years ago
Waxx are you bending the bracket in the corner left arrow? Secondly, the right arrow are you bending the metal tip toward your square?
Super exclusive ad from the Pinside Marketplace!
#26 5 years ago
waxx are you bending the bracket in the corner left arrow? Secondly, the right arrow are you bending the metal tip toward your square?
Yes, Waxx bent the trigger plate forward towards the drop target. (left arrow). This was done with two needle nose pliers. One plier to hold the bottom of the trigger plate, and one to bend it forward towards the drop target so it has a better chance of pushing it off the ledge.
#27 5 years ago
I messed around with this quite a bit and now mine works! 100% , on the owners thread about the page 58 I posted some pics of what I did.
I can offer some suggestions that might be helpful.. as far as I can tell there are 3 common drop target issues , the difference between working and not is small like 1/16 inch or less !
first try to figure out what the target is not dropping!! on mine and on most I suspect it is because the actuator nub on the trigger plate ( the piece with the red arrows above ) is not pushing the drop target off the retaining ledge with the added force of the ball behind . you can hear the coil fire but the target stays in place. if you take a pair of needle nose pliers and slightly bend the nub towards the drop target so it is just shy of protruding above the retaining ledge it should fix it . while doing Anchor the coil relay (magnet ) portion (right red arrow )with another needle nose so as not to change the angle on that side of the plate ., I ended up gluing a piece of plastic to the target so less travel is required by the trigger plate but this probably was not necessary
if the coil relay portion of the plate is too far away from the magnet, the plate will not move at all , you will hear a soft click , and can see that the trigger plate is not being pulled in if you activate with the playfield raised, , so you will need to bend the coil plate section closer ( right arrow) to the magnet, anchor trigger section with needle nose as above, it can be a little tricky bending the plate as if you do not have it firmly anchored the you will change the other tigger sides angle as well . I learned this! I ended up putting a washer between the the coil relay and the bracket to close the distance and it accomplishes the same thing as bending the plate
if the target does not stay up either the actuator nub is protruding too far or the target is not catching on the edge of the retaining ledge, stern had a fix for this for other drop targets which consisted shimming the ledge with a thin washer to make it protrude a little farther. I have seen posts of people making a shim from a credit card to do the same thing.
I talked to stern and given that I was the second owner they did not send me a whole assembly but did send me a new trigger plate , looks exactly like the old one!
if any one got a new assembly that looks different from the old one would love to see a picture
#28 5 years ago
People also bend the top bracket in which the coil is mount down to reduce the gap between the bracket and the coil.
Edi: pinballjj Yeah, thanks for describing that for me a little better than what I can do on my phone.
#29 5 years ago
Thanks for the info guys. I should have the whole new drop assembly by tomorrow. I'll take a few pics and compare them to see what the difference is, if any. I will try what you guys say and slightly bend the parts. I'll do my best. Appreciate the clarifications.
#30 5 years ago
Yah waxx,I think we have both been through this fix, probably the best advice to give is to say take the mech off the machine and play with it until you understand how it works and then the aim of all the fixes will make sense.
Good luck to the op with the new mech, in the meantime as mentioned you can disable it either from the menu or 100% by unplugging
It was very frustrating to play a new machine and keep on having to take off the glass to free the ball,once fixed the game is a lot of fun.........,challenging fun I would say!
#31 5 years ago
All, I messed with the mech and bent it slightly as suggested, and before I put it back together the damn tension spring shot from the machine. Unable to locate it, so I got it back got together without the spring, and it worked just fine. Then, I opened up the machine again and noticed on the speaker magnet there was the spring. I put the spring back on and once again played the game. The ball got stuck again. I removed the spring and it worked again. Tension spring the problem?
#32 5 years ago
If it is working without the spring do that.
#33 5 years ago
whatever works! my understanding is that the springs job is to keep the trigger plate nub off the the drop target when it goes up so without it you might have problems with the target not staying up but see how it goes !
#34 5 years ago
Good work everyone. Now Kholmes will know how to fix his Star Trek when it has the exact same issue.
#35 5 years ago
Guys, so I received the new part from Stern. I see no difference whatsoever and in just using the mech after taking it out of the package, it still doesn't appear to work, mechanically. There is still a gap so the target will not drop. See below pics.
20181013_101159 (resized).jpg20181013_101159 (resized).jpg20181013_101205 (resized).jpg20181013_101205 (resized).jpg20181013_101216 (resized).jpg20181013_101216 (resized).jpg
#36 5 years ago
The reality of it is Stern most likely sent you the exact same mech hoping that by trying stuff you will figure it out! You didn't really need the new mech, but that was the easiest thing for them to do. They mean well though.
The best thing you can do is study the problem and try to learn WHY its not working. Then make slow adjustments to correct the issue. I was at @Waxx's house when we fixed his game. There are probably many ways to fix this, and Waxx is correct that the MapleSyrup method is probably the 'easiest' way to approach this. If that is not working for you I would suggest trying to bend the trigger plate.
When you play the game you will most likely hear that it is trying to push the target off the ledge, it simply doesn't have enough power to do it with the added weight of a ball on the drop target. You can help it out by bending the trigger plate forward a bit to give it more leverage, and additionally if needed bending the trigger plate closer to the magnet.
Go slow, make small adjustments and test. Look at what is happening to see if what you are doing is helping.
Don't get too frustrated and keep trying you WILL figure this out and it will be a great feeling once you do.
See picture, I hope this helps.
1.) Bend red highlighted section in direction of red arrow 2-3 millimeters. Test
Optionally if needed
2.) Bend blue highlighted section in direction of blue arrow 2-3 millimiters. Test
Note: The MapleSyrup method is basically doing the same thing in an easier way. i.e. moving the trigger plate closer to the target.
Screen Shot 2018-10-13 at 11.01.51 AM (resized).pngScreen Shot 2018-10-13 at 11.01.51 AM (resized).png
#37 5 years ago
Ok thanks, I'll give it a shot. It's still a manufactured defect. A poor design in my opinion. Appreciate all the help from everyone on this post.
#38 5 years ago
I also want to say thanks to everyone here. I too received a replacement part (just the bracket that needs the bending) and it was identical to the one that was installed. We wound up just fixing the installed one and now have a spare. In our case we did the blue bend. It was so far away from the magnet that it would never engage. Honestly I don't why they simply don't do a gap check on these before they leave the factory.
While I can't deny that making the spring shorter/stronger seems to have helped fix this problem for people here, I must say I don't understand how or why. It doesn't make sense. If anything, it should make the problem worse as it's making it harder for the magnet to pull the bracket up. I'm pretty convinced bending this bracket ever so slightly is the solution.
Lastly, I'm not sure how people are bending this, but we removed the two screws that hold the bracket in on the left side. That allowed us to finagle the part out the right side, bend it, and put back in without having to remove anything else.
#39 5 years ago
When we fixed @Waxx's, I held the middle of the trigger plate with a needle nose pliers from one side and he bent the red part from other side with a pair of needle nose pliers.
#40 5 years ago
Guys, I ended up with a whole new mechanism assembly from Stern. It had a different circuit board on it and everything else looked the same. As soon as it was hooked up, the game has worked flawlessly since. Again, no difference in the assembly. The board changed gameplay maybe???
3 weeks later
#41 5 years ago
I received a replacement drop target mech yesterday and put it in today.. I see quite a big difference from comparing the old to the new ( little plate # 24). The original is on the left...replacement is on the right. The original even has 1 washer spaced on the magnet to shim it closer to the plate in the pic. Zero adjustments needed on the replacement and has been perfect thus far. Just thought I would post it up.
2 months later
#42 5 years ago
Just had the same issue. I put a washer under the small coil to move the coil away from the mounting bracket and close the gap between the coil and the spring loaded piece that drops the target. So far it seems to be working fine.
4 months later
#43 4 years ago
my orb does not seem to work badly, it does not stay up and it does not happen that it retains the ball. The problem is that it seems that the target goes late. the ball leaves the orb before the bull goes up. for a few thousandths of a second it seems that the bullseye goes up later and does not catch the ball
#44 4 years ago
serious some video of the failure that has the capture orb.el.mecanismo works well but it seems that it would act late
#45 4 years ago
someone who can help me? it seems that when the ball enters the orb the target goes up and down twice before catching the ball ... sometimes it seems as if it raised the target later and spits the ball out instead of retaining it.thanksss
#46 4 years ago
Does anyone else happen to the target orb does not catch the ball? it seems that the bull's eye rises later
#47 4 years ago
It seems that after reading many comments I decided to follow the messages of the forum. I made as many and double the metal sheets. It appears that the orb block works well. But fix this to cause another problem, when the target is raised right on the moment that the ball passes by the magnet, the ball gives a small boat because of the impact of raising the target and the magnet does not manage to catch it ... any advice??
#48 4 years ago
if what you are saying is that the magnet does not grab or alter the ball much after leaving the orb one thing to try is to move the magnet closer to the playfield by placing a washer or two between the magnet attachment screw and its holdng bracket underneath the playfield
others have put a new post rubber (thicker)? on one of the orb posts to give the ball a little bump to slow the ball and move it towards the magnet as it leaves the orb
#49 4 years ago
Quoted from pinballjj:
si lo que estás diciendo es que el imán no agarra o altera la bola mucho después de dejar la órbita, solo hay que intentar que el imán se acerque más al campo de juego colocando una arandela o dos entre el tornillo de fijación del imán y su soporte de sujeción debajo el campo de juego
¿Otros han puesto un nuevo post de goma (más grueso)? en uno de los postes del orbe para darle a la pelota un pequeño golpe para desacelerar la pelota y moverla hacia el imán cuando sale del orbe
I do not mean that ... all that is already done. I mean that just at the moment when the ball goes through the magnet, the avanable target gets up and having strength when climbing the ball hits a small boat, just enough so that the magnet does not grip it
#50 4 years ago
is not that ... all that is already corrected. I mean that just at the moment when the ball goes through the magnet, the orb target gets up and having strength when climbing the ball hits a small boat, just so that the magnet does not grip it
$ 6,995.00
Pinball Alley
$ 27.95
Protection
$ 19.00
Pin Monk
Other
Space Coast Pinball
Other
$ 44.99
Pinball Shark
Shooter rods
$ 55.00
PinballReplacementParts
$ 16.50
Led
$ 29.99
Cento Creations
Decals
$ 44.99
Pinball Shark
Shooter rods
$ 427.00
PinWoofer
Sound/Speakers
$ 399.95
Pin Stadium Pinball Mods
Led
6,999
West Chicago, IL
$ 49.99
PinWoofer
Sound/Speakers
$ 39.00
$ 54.99
Shooter rods
6,800
Linn Creek, MO
$ 60.00
Tools
Performance Pinball
Tools
$ 649.95
Led
$ 22.50
Precision Pinball prod.
Flipper parts
NO GOUGE PINBALL™
Other
$ 54.99
Shooter rods
Flipper parts
$ 69.99
Pinball Shark
Shooter rods
$ 7.95
Toys/Add-ons
$ 54.99
Shooter rods
This page was printed from https://pinside.com/pinball/forum/topic/guardians-of-the-galaxy-drop-target-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
