Following HowardR 's help I managed to get the machines playfield powered up and all seemed ok, though it never went to game over correctly. The motor shut off, but the playfield was still live. However, today, as I'd not had time to touch it since, I switched it on again today so that I could fine tune it, etc and fix the game over issue. . But after some time the O relay began to stay locked in and out at times with the motor constantly running. I have tried to find the problem but no joy and it's now continually doing this:
From start, reels zero, credit reel decremenents, motor continues to run and the O relay pulses on and off and the 5 balls do not release. The playfield is live, I.e flippers, pops are ok. Manually releasing the balls and adding 10 points will energise the ball trap relay ok and the motor stays running. If i drain all five balls, it kicks the game over relay in, match light and game over light comes on in backglass and the O relay is always now energised and playfield is still live.
If i start the game again, the cycle stays the same.
To give you an idea of how bad it was when i first started work, take a look at the images, before and after ( ignore the earth cable, its left loose in case I have to pull the motor board out). Lots of stray cables, cut, coils missing ( I bought the machine as a project....)
Any ideas and suggestions welcome!
IMG-20211110-WA0002 (resized).jpegIMG-20211028-WA0008 (resized).jpegIMG-20211028-WA0001 (resized).jpeg
