(Topic ID: 257085)
GTB Vulcan "game over" logic inverted
By EJS
1 year ago
  • 13 posts
  • 7 Pinsiders participating
  • Latest reply 11 months ago by Tuukka
#1 1 year ago
Here's one I haven't seen before.
During power up or tilt the "game over" light is off. I start up a game, the sequence is flawless. However once I'm on ball 1 my "game over" is lit. I've been playing around with the associated relays and the seem to be adjusted well. The system will not advance past ball one. Both my trough switches are good and ball advance unit works great during reset sequence. I can add up to 4 players. Playfield features reset after drain but stays in ball 1. The stepper in the back does not seem to put in any effort to advance ball so being gummed up isn't an issue. I can add a quick video here if that helps (or add more data when I'm more awake). Spent a bit of time making sure contacts are clean and no broken wires. Could there be a bad connector or contact somewhere? I haven't paid too much attention to the playfield units since scoring seems to function well.
I haven't owned this machine with it working properly could this have been a botched repair from a long time ago? Came out of a basement where it sat for a long time. I've spent a little time cleaning up some of the stepper units since I also had some reset issues. As of now I can start a new game every time without it hanging up.
#2 1 year ago
I would make sure steppers return to start position after start and brass contacts line up properly.
#3 1 year ago
This seems to be in the Player Unit. Have you checked the coils with a multimeter?
#4 1 year ago
The circuit for the “Add Player Unit” coil that steps up between players and balls is one of the more complex on a multiplayer game. Do you have the schematic? The pathway during startup and regular gameplay are different.
Also: greetings, neighbor! I life in Afton, which is right next to Woodbury, as I’m sure you are well aware.
#5 1 year ago
Quoted from EJS:
Does the Add Player Unit (P) relay activate when this happens?
#6 1 year ago
Hi everyone!
I have some good news and some....more data that may be helpful.
First off, thanks everyone for the responses!
The good news. The "game over" light issue has been resolved. I found an issue with my common wire in the backbox which had severed the rest of my lighting, and in turn, goofed up the rest of my lights. After seeing this I'd guess this would create less lighting, than false positives. I was hoping this issue would be connected to the rest of my problems but it appears to only be a lighting issue, which, can fortunately be put behind me.
I can get more than one player to add such as two/ or 4 players. howardr I think you might be onto something regarding your last post. Here's where it gets interesting. When I receive the ball again in a two player game (while still in player 1 ball 1), hitting the start button will perform a reset....where if it was working normally should be player 2 ball 1. If I just start up a one player game and manually advance the stepper in the back to player 2 ball one, then drain, the machine correctly advances to player 2 ball 1 as if everything is working correctly. However, if I start a two player game this will not work. In other words, the machine will step to player 1 of the next ball if I force the machine via the stepper into a player that wasn't added to the machine.
leckmeck I think you had mentioned something along these lines too. I believe everything is properly aligned and I made sure the contacts on the disk are clean (both in head and pedestal). I did not know we were neighbors we may have to get together soon (regardless of this issue)
It sounds like my issue could be player 1 specific? I noticed the switch on the right of the front stack was bent quite a bit to accept the 4th player.
My biggest fear is someone in the 80's did a quick hack to give the grandchildren unlimited balls etc but not seeing much evidence of anything out of the ordinary.
#7 1 year ago
Quoted from EJS:
Maybe I'm missing something but this doesn't sound correct.
#8 1 year ago
Quoted from HowardR:
Correct. I forced the machine into an impossible scenario by stepping into the second player when I haven't added a second player. Ironically it allows the machine to advance correctly after a drain. Haven't had time to look at the game this week, will definitely have time this weekend.
#9 1 year ago
ejs I’m free tomorrow afternoon (and will actually be in Woodbury around noon) and all day on Sunday. If you want another set of eyes, give me a call. I’ll DM my phone number to you.
#10 1 year ago
I stopped by EJS’s house yesterday and we looked at his Vulcan issue. Two switches on the P (Add Player) and BX (Last Ball) relays needed cleaning and adjusting. Working now! It went well having two sets of hands and two sets of eyeballs.
#11 1 year ago
Thanks again everyone for the $0.02 and of course a big thank you to leckmeck for updating the thread and for lending a hand. All I did was hold the light and one end of the meter so most of the credit goes to you!
Yes, game is working great, just need to get that pesky mylar out from around the pop bumpers, replace a few (quite a few) corroded light sockets and will be ready for everyone to enjoy.
2 months later
#12 11 months ago
Sorry to hijack your thread but what are the row of lights at the top of the back box for? Mine do not light up at all.
#13 11 months ago
Match numbers.
$ 4.95
Apparel - Unisex
$ 19.25
The MOD Couple
$ 5.00
Doc's Pinball Shop
$ 8.95
$ 27.99
$ 259.99
$ 75.00
pinballmod
$ 99.99
$ 279.95
COINTAKER.COM
$ 16.00
Various Other Swag
$ 19.95
$ 299.99
$ 3.00
Doc's Pinball Shop
$ 48.00
$ 99.99
COINTAKER.COM
$ 48.00
$ 149.00
Filament Printing
$ 79.95
pinballmod
$ 48.00
$ 29.00
Pinball Photos LLC
$ 27.00
